Command derivative
02 Feb 2020 20:32 #156404 by PCW
Command derivative was created by PCW
Due to bug fixes in the PID component, its probably best that pncconf connects no signals to the PID command derivative pin
for example
net x-vel-cmd => pid.x.command-deriv
if x-vel-cmd is unconnected elsewhere, will lead to a non-working FF1 PID term
and
net x-vel-cmd <= joint.0.vel-cmd
Has problems due to the lack of synchronism with the PID
with the necessary pid.n.error-previous-target setting
03 Feb 2020 07:25 #156424 by cmorley
Replied by cmorley on topic Command derivative
Starting in 2.8?
03 Feb 2020 14:43 #156438 by PCW
Replied by PCW on topic Command derivative
The PID bug was fixed in 2.8 so 2.8 is good, but doing this for all versions would
not be harmful
It looks like this is correct in 2.9s pncconf. Not sure what version the forum poster
used or whether they had disconnected the pin by leaving the signal connected
to the PID component but not connected to joint.n.vel-cmd. Doing this makes the PID
loop untunable since the PIDs cmd-deriv pin will be used (since its connected)
but the FF1 term will not work
The bug that was fixed was that the PID component was supposed to internally
calculate the commanded and feedback velocities if its cmd-deriv pin or fb-deriv
pins (respectively) were not connected, but it turned out that this feature only
worked on fb-deriv. That is, the command-derivative (used to calculating the FF1 term)
was always calculated internally regardless of whether the PID components
cmd-deriv pin was connected or not.
08 Feb 2020 14:32 #156763 by cmorley
Looking at the code - I have already done this in 2.8 +.
git hash dc1574085
Thanks!
Chris
08 Feb 2020 15:34 #156766 by PCW
Great, thanks for the update.
Time to create page: 0.098 seconds
