Configuring double axis stepper motor
6 years 8 months ago #157603 by Arro
I did not install the limit switch yet, but "forced" the homing process with the "Home Joint" button
Anyway: how do you perform the homing process in the right way ?
It would be the next step... somewhen
Thanks cmorley
6 years 8 months ago #157604 by cmorley
There are many options - depends on what you want to do. If you don't home consistently then soft limits become useless.
If you add 'HOME_SEQUENCE = 0' in the INI to each joint then AXIS should pop up a HOME_ALL button rather then having to home each joint - might be handier.
Chris
6 years 8 months ago #157605 by cmorley
Without home switches usually one homes to visual marks by jogging the joints to marks then pressing the home button, but that reuires some changes in the INI/HAL
Chris
6 years 8 months ago #157608 by Arro
Every time I start the configured LinuxCNC before reaching the world-mode I need to re-perform the Axis-homing.
Is there a way to save it for the next start ?
Just found out.... when you need to re-home a "tandem or master" axis, first you need to un-home both of them and than homing both again !
6 years 8 months ago #157613 by cmorley
in the INI under the [TRAJ] heading add:
POSITION_FILE = position.txt
That should make linuxcnc start up with the mast position recorded when shut down.
By the way these options were available in pncconf but are probably non obvious.
Chris
Time to create page: 0.232 seconds
