LinuxCNC 2.9.0 configuration problem
6 years 8 months ago #158101 by Arro
Will give a try...
Thanks Chris
6 years 8 months ago - 6 years 8 months ago #158111 by Arro
Hi Chris,
the modification of the .Pncconfig works fine, now the A-axis can be configured (general Axis and Motor parameters have the right units).
Great job !
this must be done every time the configuration is modified ?
Have some other suggestions for the config (see attachments):
1) beside the mm/inch choice for the linear movement a deg/rad for the A axis could be foreseen (nice to have)
2) display geometry definition xyz or xyza does not affect the visualisation of all 4 axis defined in the config (= all 4 are displayed)
3) Question: is the "Max Velocity" concerned for the linear movement only ? Otherwise one additional for the angular velocity would be nice
4) the steps of +/- selection for the manual axis movement should contain also the "degs steps" for the A-axis. These are defined at the beginning of the configuration under the "Increments" section. I would make two separate "Increments" resp. +/- selection sections for length and angle
5) the Jog Speed deg/min does not seem to correspond the real value when moving (maybe only a problem with the pulses/rev definition)
6) all the regulation slides (jog speed, max velocity, override) are quite rough in the settings (with mouse pointer drag). A tipping value would be much better or at least an additional fine slide dragging with mouse roll (keeping the mouse pointer for a coarse setting)
That's it, what you think ?
Have a great Friday
Aronne
Last edit: 6 years 8 months ago by Arro. Reason: attachment adjusted
6 years 8 months ago #158148 by cmorley
You won't have to do the manual fix more then once - it only happens when changing a config from xyz to xyza.
It's fixed in the next uodate.
1) I've actually never heard of anyone wanting rad for the A Axis.
2) Display Geometry affects how the plotter displays the rotational axes; It won't do anything on a XYZ config.
linuxcnc.org/docs/2.7/html/config/ini-co...tml#_display_section
3)Max velocity sets the absolute maximum velocity of any axis - in therory ;
github.com/LinuxCNC/linuxcnc/issues/523
4) AXIS doesn't support separate rates comboboxes for linear/angular axes. You must combine them in the one box.
5) Are you talking about in AXIS or in Pncconf?
6) That's an AXIS limitation and/or a computer userspace lag problem. I don't delve into AXIS, but will look into solutios for Qtvcp's version
Chris
6 years 7 months ago #160501 by Hamada
i have problem with Pncconf for mesa card 5i25 as pictures.
Pls help to overcome
System info: OS Linuxmint 19.2
Linuxcnc 2.9
Kernel RT PREEMPT
6 years 7 months ago #160519 by cmorley
Seems to indicate there is a problem with language translations.
What language is your computer set for?
Chris
6 years 7 months ago #160538 by Hamada
I'm using English
Time to create page: 0.469 seconds
