2 Motors on Y , linuxcnc 2.9 not moving together
6 years 7 months ago #159480 by CNCFred
Dear all,
please be so kind and have a look at my ini and hal file .
I read forum.linuxcnc.org/49-basic-configuratio...-linuxcnc-2-8-master
checked my hal and ini and it seems it should be ok...seems ..but the y axis is moving only one motor when homing.
finally hardware seems to be ready , I had also home switches but want to use max limit and home as one.
I have a cartesian Linuxcnc coordinates question as well ... I read the manual but I somehow don't get it :
I first had the machine configured that standing in front the minimum is in front and the maximum opposite (on the back)..seems that is wrong ??
thank you
6 years 7 months ago - 6 years 7 months ago #159482 by CNCFred
when I put home sequence -1 in pncconf wizard for the Y joints then linuxcnc throws an error and does not start
Last edit: 6 years 7 months ago by CNCFred.
6 years 7 months ago #159486 by cmorley
Whats the error message?
The following user(s) said Thank You: CNCFred
6 years 7 months ago - 6 years 7 months ago #159487 by CNCFred
found it , pncconf puts a --1 in the ini for the homing sequence if you do negative!!
if you delete one - it works!!
and I then I had to change to cabling of one motor none of the inv. settings changed the y motors to the same direction.
now I have to find out why x does not stop at the max home instead continues ...
puh ...but I am getting better
6 years 7 months ago #159488 by cmorley
If both axis are to home together they should both have a negative home sequence.
linuxcnc.org/docs/2.8/html/config/ini-ho....html#_home_sequence
I's like to know what went wrong so I can improve pncconf.
6 years 7 months ago #159491 by CNCFred
if you delete manually one of the minus - "it works!!"
I got
HOME_USE_INDEX = NO
HOME_IGNORE_LIMITS = YES
HOME_SEQUENCE = --1
still y or y2 motor inverting did not work either.
thanks for your work!
can you help me out if I have a cnc plasma do I have coordinate the table or the tool? maybe a stupid question ....
I am bit lost ...I home at right side xmax and home and can't move to the left side...
Time to create page: 0.083 seconds
