2 Motors on Y , linuxcnc 2.9 not moving together
6 years 7 months ago #159503 by CNCFred
YES it did...I understood it like
6 years 7 months ago #159599 by CNCFred
thx Chris, I had a hardware miscalc as well.
when do you think the bug with producing double minus is fixed?
I had to configure 30 times today and each time deleting twice the - to much..
6 years 7 months ago #159600 by cmorley
are you typing the - in the sequence edit box?
The following user(s) said Thank You: CNCFred
6 years 7 months ago #159601 by cmorley
What I am getting at is pncconf assumes you want tandem motors to home together so automatically adds - to the homing sequence.
The edit box is there just so you can change the order of homing axis.
I didn't add any checks for user added minus signs as I didn't think you that possibility.
Bottom line for now - don't edit the homing sequence and it should be fine
Chris
6 years 7 months ago - 6 years 7 months ago #159603 by CNCFred
yes...sorry...thought -1 -2 means sync...will check tomorrow ...it only moved one motor without the -
Last edit: 6 years 7 months ago by CNCFred.
6 years 7 months ago #159604 by cmorley
minus does mean sync in the INI - Pncconf adds it automatically
Time to create page: 0.373 seconds
