default and max velocity limited?
6 years 7 months ago #159821 by CNCFred
Dear all,
I would like to know why max velocity is limited to 2000mm/min and default velocity is limited to 1000mm /min in pncconfig
I have a problem that my motors are turning to slow and I seek to accelerate them.
thx
6 years 7 months ago #159826 by cmorley
What would be a good limit?
The following user(s) said Thank You: CNCFred
6 years 7 months ago - 6 years 7 months ago #159847 by CNCFred
Thank you that is a relief, :-)
I am new to plasma cnc my search showed that they have up to max velocity 9500mm/min so default should be 9000mm/min? I think
that makes it clear why mine is slow :-) with 33,3mm/s
I like to use the wizard and not already tweak by hand a default setup.
thank you again
Last edit: 6 years 7 months ago by CNCFred.
6 years 7 months ago #159854 by cmorley
So I upped it to 20000.
Chris
6 years 7 months ago #159858 by CNCFred
Thank you ...
I compiled the package manually on debian 10 and installed the package then on the same machine.
is only pncconf part copying possible? & where would I get it from?
thank you
6 years 7 months ago #159865 by CNCFred
guess I will grab pncconf.py from repo when updated,..
thx
