default and max velocity limited?
6 years 7 months ago #159897 by cmorley
The file to change is screen.glade
it's in that src/emc/usr_intf/pncconf folder but must be installed in lib/python/pncconf folder
Chris
The following user(s) said Thank You: CNCFred
6 years 7 months ago - 6 years 7 months ago #159907 by CNCFred
Chris, pls. check previous post of me, (the picture)seems commit and push not done so far it seems!
still 3 days old.
can you tell me the calculation, I am not able to get this out of the linuxcnc documentation.
thank you...
Last edit: 6 years 7 months ago by CNCFred.
6 years 7 months ago #159912 by cmorley
Yes sorry it seems I forgot to push it to master
Here you go:
File Name: screen.glade
File Size:126.69 KB
6 years 7 months ago - 6 years 7 months ago #159918 by CNCFred
/home/user1/emc/src/emc/usr_intf/pncconf/screen.glade
/home/user1/emc/share/linuxcnc/pncconf/screen.glade
/home/user1/emc/debian/linuxcnc-uspace/usr/share/linuxcnc/pncconf/screen.glade
6 years 7 months ago - 6 years 7 months ago #159919 by PCW
I think those limits in pncconf should be increased, _but_ why don't you just
edit your .ini file?
At some point (especially with a plasma configuration) you will have modifications
in your hal and ini files that will prevent you from running pncconf again so you
will need to understand how to change ini/hal file settings eventually anyway...
Last edit: 6 years 7 months ago by PCW.
6 years 7 months ago #159923 by CNCFred
I try to edit standard settings until the are ok with the wizard...quick trial and error...
for example ...velocity ..I don't know how to calculate it ..
MAX_VELOCITY = 26.6666666667 .....machine units in sec
just understood 26.6mm/sec x 60 = mm/minute in wizard
as a newbie , axes velocity and joint velocity , I change and read ini to see what changed where ...
but you are absolutely right ...I have a cross laser and and ...but still struggle with tuning...my machine is still so slow...
I am always thankful for your help!!
Time to create page: 0.337 seconds
