Motor won't spin, MESA 5i25 + 7i76
6 years 7 months ago - 6 years 7 months ago #161076 by prochj51
this is my first wiring setup with MESA cards (5i25 + 7i76).
I just wanted to test if everything is connected properly.
So I have just one motor (nema 17) and want to test a jog
so I am using just axis x.
When I run the test of axis X, I cannot make it work.
I double checked the wiring and it should be fine.
I do not know how to debug this issue.
Can someone check or test my .ini and .hal file attached please?
Another thing I noticed is that my motor gets very hot even though it does not spin.
Is it usual thing with steppers?
Another thing why I wanted to ask is why PNCCONF comments this part by default?
[HOSTMOT2] # **** This is for info only **** #DRIVER0=hm2_pci #BOARD0=5i25
I uncommented it.
Thanks a lot
Jiri
Last edit: 6 years 7 months ago by prochj51.
6 years 7 months ago #161078 by cmorley
Because Pncconf uses the direct pin names rather then using substitution.
It annoyed me to have to look up the pin name when I wanted to reference it.
Is there a way you could confirm the steps are being output on the pins?
Stepper motors can get pretty warm but not usually super quicker when doing nothing but it depends on the drive.
Chris
6 years 7 months ago #161081 by prochj51
I guess I can connect some LEDs to it and check if it gets any signal, but I will have to get some.
Or is there any tool for checking if the steps are sent over parport?
Jiri
6 years 7 months ago #161082 by prochj51
Or can I check if linuxcnc actually connects to MESA 5i25?
I have multiple options of selection of 5i25 in PNCCONF, I dont know which one to choose.
I selected the highlighted (see attached pic)
Jiri
6 years 7 months ago #161092 by prochj51
Okey so the problem might me at some configuration.
Because what I have read is that both of the STATUS LEDS on MESA 7i76 should illuminate for proper use. But only LED for power field lights up for me, not 5V LED.
The 5V should come from the parport right?
MESA 5i25 also does not illuminate. Only when I hit
mesaflash 5i25 --reload, it blinks for a short time.
Jiri
6 years 7 months ago #161099 by Clive S
prochj51 wrote: Okey so the problem might me at some configuration.
Jiri
If you are using a 5i25 with 7i76 you won't be using a PP
Have you checked the jumpers are in the correct position on the boards
Time to create page: 0.296 seconds
