Z and Y axis moving the wrong way?
6 years 6 months ago #162704 by Catch22
Ok so I've been trying to tune everything today and I think it's going pretty good except the z and Y axis are moving the wrong way, so I go into ini file and change the output scale from 10 to -10 but when I do this and start up linuxcnc the axis runs away. I'm not really sure why it's doing this.
6 years 6 months ago #162705 by PCW
To reverse the direction of a analog servo you need to change both the analog
output scale and the encoder scale
The following user(s) said Thank You: Catch22, superlen
6 years 6 months ago #163348 by andypugh
Catch22 wrote: Ok so I've been trying to tune everything today and I think it's going pretty good except the z and Y axis are moving the wrong way
Before you change anything, are you sure that things are moving the wrong way?
Increasing Z should increase the gap between the spindle and the table.
Increasing Y should move the spindle backwards relative to the table.
With moving tables it is easy to get confused.
6 years 6 months ago #163368 by OT-CNC
Easiest way to visualize this is the keyboard keys reflect the direction of travel of the cutter. On a table machine jogging left key is table movement to the right.
Your encoders have to reflect that. Make sure you have the encoders counting in the right direction. So on your Z the count has to increase when moving up. Confirm that 1st before attaching the motors.
6 years 6 months ago #163753 by Catch22
PCW wrote: To reverse the direction of a analog servo you need to change both the analog
Thanks PCW this was the problem, needed to change both, everything is moving the correct way now.
Thanks everyone for your help.
