stepper settings/ calculation set up
6 years 5 months ago #166449 by motal2004
Replied by motal2004 on topic stepper settings/ calculation set up
go it figured out. it helps writing out all the steps of the calculations.
Thanks again guys for all the help.
  • Moderator
  • Moderator
6 years 5 months ago #166485 by tommylight
Replied by tommylight on topic stepper settings/ calculation set up
Nice.
You are welcomed.
6 years 5 months ago - 6 years 5 months ago #166488 by rodw
Replied by rodw on topic stepper settings/ calculation set up
Todd Zuercher wrote: Racks (non metric ones at least) are usually specified in diametrical pitch, This means that a 20 pitch pinion of 1 inch diameter would have 20 teeth and the matching rack would have 20 teeth cover pi inches (about 3.14 inches). So one rev of your 22 tooth pinion should travel 22(pi)/20 inches.
You guys really do it the hard way. In all the other contries in the world (minus one other obscure one) metric makes it so much easier
Take Tommy's module 2, 20 tooth pinon,
The diameter is 2 * 20 = 40mm
The Circumference (distance travelled) is 40mm * pi = 125.66mm
The silly bit is that the world agreed to use the same methods for invloute gears back in WW2 (or was it WW1) but the insistance to quote TPI just makes it harder for you guys.
Last edit: 6 years 5 months ago by rodw.
6 years 5 months ago #166508 by Todd Zuercher
Replied by Todd Zuercher on topic stepper settings/ calculation set up
The circumference is 2 * 20 = 40mm
The diameter (distance travelled) is 40mm * pi = 125.66mm
The only difference is inversion, the calculations are almost the same, other than the units difference.
PS: 40mm would be the diameter, 125.66 would be the circumference.
6 years 5 months ago #166566 by rodw
Oops, sorry, I updated what I said. I've been immersed in this stuff with a US based engineer the last couple of days who is working in SI units. This morning he said:
Rod, in your distance traveled calc per pinion rev - my research showed that a 30mm diameter pinion is the pitch diameter. You guys are clever enough to call it by it's useful name
6 years 5 months ago #166579 by bbsr_5a
Replied by bbsr_5a on topic stepper settings/ calculation set up
you need the pitch of the belt system
there are Inch and Metric belts available
GT2 for instance is metric 2mm Metric is 5mm or 10mm Standard
the Inch ones are module m=d/z
but better to messure is the outside diameter m=da / 7(z+2)
and d=Workdiameter=m*z
worklengthPerRev= U = d*Pi THATS the Value you need for calculation
if you got the m you got P as m=P / Pi -> P= m * Pi
so you got
d= (z*P) / Pi
Sorry Education Personal
Time to create page: 0.299 seconds
