Motor encoder scaling
6 years 3 days ago #187631 by PMCD
Replied by PMCD on topic Motor encoder scaling
Everything is correct as you have explained.
I have the analogue enables for x and y pulled from the 7I77 board.
Using only the z motor which is uncoupled from the axis, I enabled the servos and the motor drifts at about 2rpm then toggled F2. There is a quick jerk of the motor then a 'joint following error" on the screen.
should I play with PID tuning now?
Peter
6 years 3 days ago #187637 by PCW
Replied by PCW on topic Motor encoder scaling
If you get a quick move and a following error when enabled,
its likely you have the feedback reversed.
Here is a basic tuning sequence for velocity mode drives:
gnipsel.com/linuxcnc/tuning/servo.html
6 years 3 days ago - 6 years 3 days ago #187642 by PMCD
This is how I have the encoders wired.
Peter
Last edit: 6 years 3 days ago by PMCD.
6 years 2 days ago #187719 by PMCD
So I've been playing around with encoder scale in the INI file for the 'Z' axis and am get some better result The motor is still drifting (slower) and now there is a delay (3s) before I get the following error when I start Linuxcnc,
From the attached document in my original post is there a correct figure I should be using in the encoder scale.
The last number I tried was 24576 for MKD041 motor
Peter
6 years 2 days ago #187731 by tommylight
Replied by tommylight on topic Motor encoder scaling
If the motor is drifting while enabled, there is something wrong with the wiring or configuration, so:
Check if the drive is set to output INCREMENTAL values,
open halshow and check the number of raw encoder counts while the drive is disabled by moving the motor exactly one turn by hand,
And since it seems to me there might be more than one issue there, have a read through this, especially the wiring and checking parts:
6 years 2 days ago - 6 years 2 days ago #187738 by PMCD
H Tommy,
I think the wiring is ok.
I have had some success this morning since my last post.
Here is what I did
I changed these figures in the ini file.
Z MKD041 encoder scale 21000 (PncConf had these at 600 800 and 1600)
Y MKD041 encoder scale 21000
X MKD071 encoder scale 32000
Now when I enable the servos I get a small amount of drift until I toggle F2 then they stop and I am able to jog each axis around. The direction is correct but the DRO does not match the machine movement now (which I expected)
I have done what you said and rotated the y axis one turn, 8000 was the count.
Last edit: 6 years 2 days ago by PMCD.
Time to create page: 3.885 seconds
