- Thank you received: 2181
No Analog voltage change 7i76e
5 years 10 months ago #191150
Replied by cmorley on topic No Analog voltage change 7i76e
Need to issue m code to start spindle in MDI mode.
Idiosyncrasies of linuxcnc
Linuxcnc is somewhat sloppy in it's modes (switches modes behind the scenes) and yet rigid at the same time.
- ronthomp
5 years 10 months ago #191151
by ronthomp
Replied by ronthomp on topic No Analog voltage change 7i76e
That worked. Thanks!
If I issue M3 to start the spindle then further S commands will vary the speed as it should. Thanks again!
- ronthomp
5 years 10 months ago #191154
by ronthomp
For anyone else who has this problem, it appears in pncconfig, I ticked a box to reverse the spindle because it turned the wrong way in the open loop test. I unticked the box and that fixed the ini file -5000. Unticking the box has no effect in the machine operation. My spindle turns the right way per M3 and M4 commands in MDI.
Time to create page: 0.132 seconds
