- Thank you received: 7491
7i76e VFD configuration
5 years 10 months ago #192830
Replied by tommylight on topic 7i76e VFD configuration
Almost all VFD's have a setting to enable outside control, see if you can find that.
- robertspark
- Thank you received: 216
5 years 10 months ago #192838
by robertspark
Replied by robertspark on topic 7i76e VFD configuration
it depends upon the spindle motor and what your settings are in the VFD.
some spindle motors are designed to operate at 400hz,
check the settings within the VFD with regards to the set number of poles and its current rating and settings and also the motor frequency (from the drive to the motor).
120 * 400hz / 2 pole = 24000 rpm
Minimum frequency (setting in the drive) = 6000rpm * 2pole / 120 = 100hz
- DarkVortex
5 years 10 months ago #192849
by DarkVortex
Replied by DarkVortex on topic 7i76e VFD configuration
Alright, I got it worked out. My VFD has an especially bad manual, but multimeters are the best.
I ended up doing the following:
Mesa 7i76e --> VFD
Spindle- --> GND
Spindle Out --> AI1 (Configured to be 0-10V input)
Spindle+ --> 10V
Ena+ --> X1 (Configured to be "FWD" in VFD settings)
Ena- --> COM (Grounded end of VFD 24VDC supply)
I belive the way this VFD works / is currently configured is that it looks for X1 (normally at +24V) to be brought to ground. When this happens, like when the mesa closes the "enable" switch, the spindle is turned on, set to the RPM configured by the mesa's "digital potentiometer". I could spend more time poking around trying to figure out the best way to actually have direction +/- control, but I really don't need it and I'd rather spend time getting a spoil board and fixture plate machined up and mounted!
Mesa 7i76e --> VFD
Spindle- --> GND
Spindle+ --> 10V
5 years 10 months ago #192879
Glad you got it working.
Time to create page: 0.131 seconds
