ppnconf - "Create simulated hw conf" missing
5 years 9 months ago #194627 by Fiury
Thank for help , just installing RT19.1
gnipsel.com/linuxcnc/uspace/linuxmint19-rt.html
Hope that it will fix the problem.. i will wrote ..
Thanks for support !!
  • Moderator
  • Moderator
5 years 9 months ago #194631 by tommylight
Replied by tommylight on topic ppnconf - "Create simulated hw conf" missing
Use this, it is much faster to install
forum.linuxcnc.org/9-installing-linuxcnc...nd-easy-installation
Or use the official install instructions:
linuxcnc.org/downloads/
5 years 9 months ago - 5 years 9 months ago #194640 by Fiury
Afrter 3 hours of instaling RT Kernell ....... same problem with RT Kernall
Edited
Then reinstaled linuxcnc-uspace after kernell and WORKING !!!
THANKS !
Last edit: 5 years 9 months ago by Fiury.
5 years 9 months ago - 5 years 9 months ago #194713 by Fiury
Hmm , ok, something it is doing, but :
I have max 0-0,1 V output from Pin 2 :/ ... VDF show 2 Hrz
(Mesa 7i76ED).............................VDF HY
5 years 9 months ago #194822 by andypugh
Replied by andypugh on topic ppnconf - "Create simulated hw conf" missing
What does HAL show for the value going in to the ...analogout0 pin in HAL?
The 0.1V is measured with a multimeter at the Mesa terminals?
Do you also measure 10V there?
5 years 9 months ago - 5 years 9 months ago #195023 by Fiury
Do you also measure 10V there? ..... OK
Not giving 0-10 (measured with a multimeter) , but oly 1.1-1,4 at the Mesa terminals? :(
File Name: cnc_2021-01-14.ini
File Size:5 KB
File Name: cnc_2021-01-14.hal
File Size:13 KB
ACM to Pin 1
VI to Pin 2
+10 to Pin 3
nothing to Pin 4
DCM to 5
FOR to Pin 6
DCM to Pins 7
REV to Pin 8
Configured VFD HY
PD001 = 1...OK
PD002 = 1 .......(but Hrz still can be set only manualy on VFD) :(
PD044 = 1.....OK
PD045 = 5.... OK
Can you check it pls?
(axis are not set pls check only spindle setup)
Time to create page: 0.149 seconds
