7i98 and 5abobx3 firmware
5 years 8 months ago #197560 by jonnydeen
Replied by jonnydeen on topic 7i98 and 5abobx3 firmware
That would indeed be much simpler, thanks
Any thoughts as to why the direction pins are not where I'd expect them?
5 years 8 months ago #197562 by PCW
Replied by PCW on topic 7i98 and 5abobx3 firmware
I would first renumber the stepgens and try again
5 years 8 months ago #197563 by jonnydeen
I'll give that a go, thank you for your input. Your help hab been much appreciated
5 years 8 months ago #198744 by jonnydeen
Just to conclude, changing the Stepgen numbers in hal seems to have done the trick. Step & dir signals are now where they are supposed to be. However I haven't tried the other functions yet.
They are now;
X = stepgen 0
Y = stepgen 1
Z = stepgen 2
A = stepgen 3
1 month 2 weeks ago #349616 by Marslukan
Replied by Marslukan on topic 7i98 and 5abobx3 firmware
Всем доброго дня.
Подскажите, можно ли достать такую прошивку, нужно: 1 мотор, 2-3 step/dir, 5 энкодеров и остальные разные кнопки, переключатели?
Или как можно изменить текущую прошивку, в какой программе?
1 month 2 weeks ago #349619 by PCW
If you indicate what the exact pinout required is, I can build the firmware.
The following user(s) said Thank You: Marslukan
Time to create page: 0.099 seconds
