- Thank you received: 140
PCW wrote: Note that disabling RT CPUs with isolcpus may in fact make your
Ethernet and LinuxCNC latency worse.
The latency test really only tests dispatch latency, overall LinuxCNC latency
actually doing things will typically be significantly worse. Watching the
.tmax values shows the actual latency
