- Configuring LinuxCNC
- Configuration Tools
- PnCConf Wizard
- Z axis travel/ Program exceeds machine maximum on axis Z
- Bearfood
20 Mar 2021 16:29 #202993
by Bearfood
Z axis travel/ Program exceeds machine maximum on axis Z was created by Bearfood
I'm back at this finally and trying to figure out new issues. When you hit + on the Z what direction should it travel? I'm assuming up.
When in the initial linuxcnc screen after I home all the joints I can only move the Z axis down which means it won't rise off the table. I also get the error "Program exceeds machine maximum on axis Z" when I try to execute the initial logo program. What am I doing wrong?
Any help is appreciated.
- Thank you received: 7481
20 Mar 2021 17:52 #203000
Replied by tommylight on topic Z axis travel/ Program exceeds machine maximum on axis Z
Most probably wrong limits/home/offset in the ini file.
If you upload the hal and ini file here we can have a look and point to whatever might be out of place there.
- Bearfood
21 Mar 2021 15:37 #203123
by Bearfood
Replied by Bearfood on topic Z axis travel/ Program exceeds machine maximum on axis Z
I think I've figured it out through watching this video.
It's a great beginner guide to pncconf. I'll try to reset my configuration tonight.
- Bearfood
21 Mar 2021 22:10 - 21 Mar 2021 22:19 #203164
by Bearfood
Spoke too soon, I've got it so that I can travel up but still can't run the simulation with the stated error. Attached are the HAL and INI files.CNC is 48" X and Y with a 5" ZAny help is appreciated. For some reason it's not letting me attach the .ini file so I've renamed it to txt.
Last edit: 21 Mar 2021 22:19 by Bearfood.
- Bearfood
23 Mar 2021 17:58 #203412
by Bearfood
Any thoughts on the Hal and Ini files? Sorry, this may not be on your radar after my initial response.
- Clive S
- Thank you received: 486
23 Mar 2021 19:34 #203419
by Clive S
[TRAJ]
COORDINATES = XYYZZ
It looks like you are missing joint 4 from the ini
Replied by Clive S on topic Z axis travel/ Program exceeds machine maximum on axis Z
[TRAJ]
COORDINATES = XYYZZ
- MaHa
- Thank you received: 240
23 Mar 2021 20:22 #203427
by MaHa
Replied by MaHa on topic Z axis travel/ Program exceeds machine maximum on axis Z
Beside incomplete .ini file JOINT3 and JOINT4, if retracted Z-Axis is home zero, try this entrys in AXIS_Z , JOINT_3 and JOINT_4
MIN_LIMIT = -5
MAX_LIMIT = 0.001
MIN_LIMIT = -5
MAX_LIMIT = 0.001
- Bearfood
25 Mar 2021 19:43 #203633
by Bearfood
Tried that and linuxvnc errors out stating a problem with axis z max limit.
Not sure what you mean by incomplete joints 3 &4
To the other note the machine has 1x, 2y and 2z joints. I don't think I'm missing one but let me know if you feel that's incorrect.
- Clive S
25 Mar 2021 20:05 - 26 Mar 2021 08:20 #203635
by Clive S
In the ini file that you posted it looks like the Z joint looks incomplete plus if you have 2 motors on Z you need a joint for each one
Last edit: 26 Mar 2021 08:20 by Clive S.
- Bearfood
26 Mar 2021 19:22 #203741
by Bearfood
I tried setting my z home to be 3 inches above the table. When I run the program it still gives me the error and if I proceed it plunges right down and stops at 0. I'm sure I'm doing something simple and stupid.
The ini and Hal files are straight out of pncconf so I'm not sure how q joint or joints would be incomplete given there were no errors. I've modified again through pncconf but still don't see any issues.
- PnCConf Wizard
