trouble shoting "Pin 'hm2_5i25.0.7i76.0.0.input-24' does not exist 4977"
5 years 2 months ago #219062 by PCW
Can you run
sudo mesaflash --device 5i25 --readhmid
and post the results here?
Also how are the 7I76 and 5I25 cable power jumpers set
and do you have 2 yellow LEDS illuminated on the 7I76?
4 years 7 months ago - 4 years 7 months ago #237722 by garrettmin
Diagnostic = Bad Cable @ DB25 to IDC26
7i92 Manual has statement:
the 7I92 can supply up to 1A of 5V power to each of the daughter cards.  If you use this option you must verify that the interface cable does not tie the eight parallel port ground wires together as some cheap printer cables do. Mesa supplied IEEE-1284 cables are the best option
7i92 Manual has the DB25 to IDC26 Pinout:
DB25
1 & 14
2 & 15
3 & 16
4 & 17
Is this the correct Pinout for Mesa DB25M to IDC26?
image missing http://www.suntekpc.com/image/cable-add-db25f.md6f-oem-190325c-pinout-800-db25f.jpg
Last edit: 4 years 7 months ago by garrettmin.
4 years 7 months ago #237723 by PCW
Yes, a IDC cable HDR26 --> DB25 has the correct pinout.
(with pin 1 --> pin 1 and HDR26 pin 26 unconnected)
4 years 7 months ago - 4 years 7 months ago #237728 by garrettmin
4 years 7 months ago - 4 years 7 months ago #237745 by garrettmin
4 years 7 months ago - 4 years 7 months ago #237749 by PCW
A correctly made IDC cable is all that's required .
(as long as you have IDC-HDR26 pin1 to IDC-DB25 pin one, its correct)
Is field power connected on the 7I76?
Normally you would _not_ connect to VIN but rather connect
to field power (and leave W1 in the left hand position)
Last edit: 4 years 7 months ago by PCW.
Time to create page: 0.320 seconds
