5i25+7i76 to 7i76E config conversion
- eman5oh
- Thank you received: 11
22 Dec 2021 19:36 #229755
by eman5oh
5i25+7i76 to 7i76E config conversion was created by eman5oh
Hi all, I had a working 5i25+7i76 setup running my 3 axis Bridgeport mill and would like to modify my config to run the 7i76E. I have the 7i76E running on a test setup and was wondering what the simplest way to modify the config to run the new Mesa card would be? Thanks
- Thank you received: 5308
22 Dec 2021 22:02 - 22 Dec 2021 22:02 #229766
Replied by PCW on topic 5i25+7i76 to 7i76E config conversion
It should be pretty simple to change. Basically all that needs to change
is the card name (from 5i25 to 7i76e) and the driver name/command line,
loadrt hm2_pci config="blah.blah blah"
to:
loadrt hm2_eth board_ip=10.10.10.10 config="blah.blah blah"
to:
Last edit: 22 Dec 2021 22:02 by PCW.
- eman5oh
24 Dec 2021 17:40 #229907
by eman5oh
Replied by eman5oh on topic 5i25+7i76 to 7i76E config conversion
Thanks, PCW, got everything working minus my handwheel mpg, the line below is what is causing the issue and I have attached the debug report. Commenting that line out lets the machine function without the mpg, I can jog it around with the mdi buttons on the screen at least.
net mpg-out ilowpass.0.in <= hm2_7i76e.0.7i76.0.0.enc0.count
net mpg-out ilowpass.0.in <= hm2_5i25.0.7i76.0.0.enc0.count previous hal line used with the 5i25 7i76 combo.
24 Dec 2021 17:54 #229908
Do you still have a "sserial_port_0=20xx" token in the driver config line?
- eman5oh
24 Dec 2021 18:09 #229911
by eman5oh
That was it, thank you!
- eman5oh
24 Dec 2021 20:50 #229922
by eman5oh
I have the machine back up and running now, everything works as before but I am getting the below messages shortly after starting linux cnc up. Looking through my config , I don't see anything that may cause this but, I am not an expert. I have not cut any parts with the machine but it seems to run just fine. i am running the latest stable raspberry Pi image downloaded from this site on a 4gb Pi4
Thanks. again for the help.
hm2/hm2 7i76e.0: Smart Serial port 0
: Dolt not cleared from previous servo
thread. Servo thread rate probably to
o fast. This message will not be repea
ted, but the hm2 776e.0.sserial.0.fau
It-count pin will indicate if this is happ
ening frequently.
Unexpected realtime delay on task o
with period 1000000 This Message will
only display once per session Run the Latency
Test and resolve before continuing
ening frequently.
25 Dec 2021 00:28 #229940
Do you have isolcpus=1.2.3?
I think that's pretty much a requirement for RPI4 setups
Also even with isolcpus=1.2.3, some RPI4 Ethernet setups need a 2000000 ns servo thread
- eman5oh
25 Dec 2021 18:11 #229976
by eman5oh
Happy holidays ,
Looks like the pi image is set to use isolcpus=3 , I changed it to isolcpus=1.2.3 but that did not fix the issue. I set the servo thread to 2000000 ns and that got rid of the realtime delay errors but now I am getting following errors, is there something else to change along with the servo thread time that needs adjusting as well or is the Pi4 just not up to the task?
- Thank you received: 7462
25 Dec 2021 18:36 #229980
Replied by tommylight on topic 5i25+7i76 to 7i76E config conversion
Change PID "P" value to 500 for each axis/joint in the ini file.
- eman5oh
26 Dec 2021 15:22 - 26 Dec 2021 15:58 #230014
by eman5oh
***Edit*** Looks like isolcpus=1,2,3 fixed the issue. I had put in isolcpus=1.2.3 using periods and not comma’s after the proper isolcpus config was used the latency errors have gone away even while using a 1000000 ns servo thread. Thanks so much, pretty happy with the new setup now.
Changed the P to 500 still get the following errors, upped my following error and that gets rid of the messages but the machine does not run well, I get hiccups when moving the motors, they don’t sound healthy with 2000000 ns servo thread. I made a new sd card up with a fresh install and it is bit better latency wise but I do still get the warnings. If it would be better I’ll start a new post in the computer hardware section to chase this down as I now have the config well sorted for the 7i76e. Thank both of you for the help on this one.
Last edit: 26 Dec 2021 15:58 by eman5oh.
Time to create page: 0.307 seconds
