5i25+7i76 to 7i76E config conversion
4 years 10 months ago #229755 by eman5oh
Hi all, I had a working 5i25+7i76 setup running my 3 axis Bridgeport mill and would like to modify my config to run the 7i76E. I have the 7i76E running on a test setup and was wondering what the simplest way to modify the config to run the new Mesa card would be? Thanks
4 years 10 months ago - 4 years 10 months ago #229766 by PCW
It should be pretty simple to change. Basically all that needs to change
is the card name (from 5i25 to 7i76e) and the driver name/command line,
loadrt hm2_pci config="blah.blah blah"
to:
loadrt hm2_eth board_ip=10.10.10.10 config="blah.blah blah"
Last edit: 4 years 10 months ago by PCW.
4 years 10 months ago #229907 by eman5oh
Thanks, PCW, got everything working minus my handwheel mpg, the line below is what is causing the issue and I have attached the debug report. Commenting that line out lets the machine function without the mpg, I can jog it around with the mdi buttons on the screen at least.
net mpg-out ilowpass.0.in <= hm2_7i76e.0.7i76.0.0.enc0.count
net mpg-out ilowpass.0.in <= hm2_5i25.0.7i76.0.0.enc0.count    previous hal line used with the 5i25 7i76 combo.
File Name: linuxcnc.report.txt
File Size:8.21 KB
4 years 10 months ago #229908 by PCW
Do you still have a "sserial_port_0=20xx" token in the driver config line?
4 years 10 months ago #229911 by eman5oh
That was it, thank you!
4 years 10 months ago #229922 by eman5oh
I have the machine back up and running now, everything works as before but I am getting the below messages shortly after starting linux cnc up. Looking through my config , I don't see anything that may cause this but, I am not an expert. I have not cut any parts with the machine but it seems to run just fine. i am running the latest stable raspberry Pi image downloaded from this site on a 4gb Pi4
Thanks. again for the help.
hm2/hm2 7i76e.0: Smart Serial port 0
: Dolt not cleared from previous servo
thread. Servo thread rate probably to
o fast. This message will not be repea
ted, but the hm2 776e.0.sserial.0.fau
It-count pin will indicate if this is happ
ening frequently.
Unexpected realtime delay on task o
with period 1000000 This Message will
only display once per session Run the Latency
Test and resolve before continuing
Time to create page: 0.291 seconds
