5i25+7i76 to 7i76E config conversion
4 years 10 months ago #229940 by PCW
Do you have isolcpus=1.2.3?
I think that's pretty much a requirement for RPI4 setups
Also even with isolcpus=1.2.3, some RPI4 Ethernet setups need a 2000000 ns servo thread
4 years 10 months ago #229976 by eman5oh
Happy holidays ,
Looks like the pi image is set to use isolcpus=3 , I changed it to isolcpus=1.2.3 but that did not fix the issue. I set the servo thread to 2000000 ns and that got rid of the realtime delay errors but now I am getting following errors, is there something else to change along with the servo thread time that needs adjusting as well or is the Pi4 just not up to the task?
4 years 10 months ago #229980 by tommylight
Change PID "P" value to 500 for each axis/joint in the ini file.
4 years 10 months ago - 4 years 10 months ago #230014 by eman5oh
***Edit*** Looks like isolcpus=1,2,3 fixed the issue. I had put in isolcpus=1.2.3 using periods and not comma’s after the proper isolcpus config was used the latency errors have gone away even while using a 1000000 ns servo thread. Thanks so much, pretty happy with the new setup now.
Changed the P to 500 still get the following errors, upped my following error and that gets rid of the messages but the machine does not run well, I get hiccups when moving the motors, they don’t sound healthy with 2000000 ns servo thread. I made a new sd card up with a fresh install and it is bit better latency wise but I do still get the warnings. If it would be better I’ll start a new post in the computer hardware section to chase this down as I now have the config well sorted for the 7i76e. Thank both of you for the help on this one.
Last edit: 4 years 10 months ago by eman5oh.
Time to create page: 0.197 seconds
