Problems whit the switches in pncconf
4 years 8 months ago #234514 by PCW
You need to use watch, not show (show is not realtime)
4 years 8 months ago #234519 by Nest
ok, sorry by the mistake
image missing https://i.imgur.com/gaIfCl4.png
all time it's like picture, not change the colour when i push the switch but in the board the led up and down
4 years 8 months ago #234520 by PCW
Can you post your hal and ini files?
4 years 8 months ago #234521 by Nest
Yes.....
File Name: CNC3040Z-DQ.hal
File Size:10.17 KB
File Name: CNC3040Z-DQ.ini
File Size:4.33 KB
4 years 8 months ago #234522 by PCW
Hmm, that does not match your halshow listing
4 years 8 months ago - 4 years 8 months ago #234530 by Nest
i fixed it... the problem was in the hardware switches... Do I need to install pull down resistors?
i had a bad configuration at now the machive work fine.
the next step i have to configure the spindle
Thansk you for the help, the halshow has helped me a lot
Last edit: 4 years 8 months ago by Nest.
Time to create page: 0.208 seconds
