- Thank you received: 4153
OK for normally open switches you don't need inversion.
Can LinuxCNC overrun the closed switch position at home?
If so, you probably need to change the home switch mechanics
or slow the home search velocity. so it cannot overrun the closed
switch position.
eg. the home switch MUST stay triggered all the way to the limit switch.
I don't see any mention of limit switches
