7i76E SPINDLE OUT Problem
- shanham67
19 Jun 2022 22:18 #245455
by shanham67
Replied by shanham67 on topic 7i76E SPINDLE OUT Problem
.ini an .hal attached Thanks!
- Thank you received: 7462
20 Jun 2022 00:15 #245458
Replied by tommylight on topic 7i76E SPINDLE OUT Problem
All seems OK from a quick glance, that brings the question: are you using GmoccaPy?
Not sure if that is the cause/issue, but i am sure GmoccaPy does some stuff o it's own.
- Thank you received: 5308
20 Jun 2022 00:33 #245460
Replied by PCW on topic 7i76E SPINDLE OUT Problem
net spindle-vel-cmd-rpm-abs => pid.s.command
means that the spindle output is scaled directly in RPM
so unless the requested RPM is 2000, you will not get
a full scale analog output
- shanham67
20 Jun 2022 16:52 #245489
by shanham67
Ok, I am getting spindle output voltages now. I set the NO_FORCE_HOMING=1 in my .ini so I could issue S2000 M3 from the MDI. Thanks for the help.
BTW, is there a way to 'request' a spindle rpm other than and 'S' command through the MDI?
20 Jun 2022 17:59 #245491
In Axis GUI:
F9 >>>run forward
F10 >>run reverse
F11 >>speed down
F12 >>speed up
F9 >>>run forward
F10 >>run reverse
F11 >>speed down
F12 >>speed up
Time to create page: 0.142 seconds
