7i76E SPINDLE OUT Problem
4 years 4 months ago #245460 by PCW
Replied by PCW on topic 7i76E SPINDLE OUT Problem
net spindle-vel-cmd-rpm-abs => pid.s.command
means that the spindle output is scaled directly in RPM
so unless the requested RPM is 2000, you will not get
a full scale analog output
4 years 4 months ago #245489 by shanham67
Replied by shanham67 on topic 7i76E SPINDLE OUT Problem
Ok, I am getting spindle output voltages now. I set the NO_FORCE_HOMING=1 in my .ini so I could issue S2000 M3 from the MDI. Thanks for the help.
BTW, is there a way to 'request' a spindle rpm other than and 'S' command through the MDI?
4 years 4 months ago #245491 by tommylight
In Axis GUI:
F9 >>>run forward
F10 >>run reverse
F11 >>speed down
F12 >>speed up
Time to create page: 0.059 seconds
