- Thank you received: 5334
Okay, but that means I still don't grasp how to get DB25/P3 pin numbers out of the hal file.A couple notes:
1. Mesa hal files only use GPIO numbers, _never_ pin numbers.
I am not able to imagine a setup that would need this--BUT I think I've documented that I am not imaginative.2. Pins with secondary input function are still available
as inputs even if the secondary function is enabled
(so you could still use GPIO 14,15,16 as inputs with
the encoder enabled)
Not true....I still don't grasp how to get DB25/P3 pin numbers out of the hal file.
