Odd, the raspi error was a bug in Bookworm 12.0 that was fixed in the 12.1 update. I had not see it break before.
Forget the kernel for now. Do
sudo apt update
sudo apt upgrade
That should get you to 12.1
Then do the dkms driver thing
Well, the apt update and upgrade produced similar errors (RE: z50-raspi-firmware and initramfs-tools). The only thing it looks like that it actually updated was firefox and a debian/bookworm-security update. Despite these issues, it seems to be running like a champ. No more follow errors. I'll attach the output from the apt update/upgrade - it would be nice to fix this but it doesn't appear to be hurting anything (at least at the moment). Question, how can I tell if I am at 12.0 vs 12.1? I haven't run the dkms driver thing because I think the right driver is already installed during the previous. Thought?
In the meantime, I'm gonna let this thing run for a while before I attempt anything new.
~$ sudo apt upgrade
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Calculating upgrade... Done
The following packages will be upgraded:
firefox-esr libvpx7
2 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
2 not fully installed or removed.
Need to get 1,003 kB/64.1 MB of archives.
After this operation, 13.7 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1
security.debian.org/debian-security
bookworm-security/main amd64 libvpx7 amd64 1.12.0-1+deb12u1 [1,003 kB]
Fetched 1,003 kB in 0s (4,512 kB/s)
(Reading database ... 265039 files and directories currently installed.)
Preparing to unpack .../libvpx7_1.12.0-1+deb12u1_amd64.deb ...
Unpacking libvpx7:amd64 (1.12.0-1+deb12u1) over (1.12.0-1) ...
Preparing to unpack .../firefox-esr_115.3.0esr-1~deb12u1_amd64.deb ...
Leaving 'diversion of /usr/bin/firefox to /usr/bin/firefox.real by firefox-esr'
Unpacking firefox-esr (115.3.0esr-1~deb12u1) over (102.15.1esr-1~deb12u1) ...
Setting up linux-image-6.3.0-rt11-linuxcnc (6.3.0-2) ...
dkms: running auto installation service for kernel 6.3.0-rt11-linuxcnc.
dkms: autoinstall for kernel: 6.3.0-rt11-linuxcnc.
update-initramfs: Generating /boot/initrd.img-6.3.0-rt11-linuxcnc
W: Possible missing firmware /lib/firmware/i915/dg2_huc_gsc.bin for module i915
live-boot: core filesystems dm-verity devices utils udev blockdev dns.
raspi-firmware: missing /boot/firmware, did you forget to mount it?
run-parts: /etc/initramfs/post-update.d//z50-raspi-firmware exited with return c
ode 1
run-parts: /etc/kernel/postinst.d/initramfs-tools exited with return code 1
run-parts: /etc/kernel/postinst.d/z50-raspi-firmware exited with return code 1
Generating grub configuration file ...
Found background image: /usr/share/images/desktop-base/desktop-grub.png
Found linux image: /boot/vmlinuz-6.3.0-rt11-linuxcnc
Found initrd image: /boot/initrd.img-6.3.0-rt11-linuxcnc
Found linux image: /boot/vmlinuz-6.1.0-12-rt-amd64
Found initrd image: /boot/initrd.img-6.1.0-12-rt-amd64
Warning: os-prober will be executed to detect other bootable partitions.
Its output will be used to detect bootable binaries on them and create new boot
entries.
Found Windows Boot Manager on /dev/sda1@/EFI/Microsoft/Boot/bootmgfw.efi
Adding boot menu entry for UEFI Firmware Settings ...
done
dpkg: error processing package linux-image-6.3.0-rt11-linuxcnc (--configure):
installed linux-image-6.3.0-rt11-linuxcnc package post-installation script subp
rocess returned error exit status 1
Setting up initramfs-tools (0.142) ...
update-initramfs: deferring update (trigger activated)
Setting up libvpx7:amd64 (1.12.0-1+deb12u1) ...
Setting up firefox-esr (115.3.0esr-1~deb12u1) ...
Processing triggers for hicolor-icon-theme (0.17-2) ...
Processing triggers for libc-bin (2.36-9+deb12u1) ...
Processing triggers for man-db (2.11.2-2) ...
Processing triggers for mailcap (3.70+nmu1) ...
Processing triggers for desktop-file-utils (0.26-1) ...
Processing triggers for initramfs-tools (0.142) ...
ode 1
dpkg: error processing package initramfs-tools (--configure):
installed initramfs-tools package post-installation script subprocess returned
error exit status 1
Errors were encountered while processing:
initramfs-tools
E: Sub-process /usr/bin/dpkg returned an error code (1)
