How to tell if i have a 7i96 or 7i96s
02 Dec 2023 16:16 #287031 by Craig E
How to tell if i have a 7i96 or 7i96s was created by Craig E
Hi all I am upgrading my system from Raspberry Pi to PC and do not remember if I have a 7i96 or 7i96S is there a way to tell and what firmware is running?
Also, should I upgrade the firmware if I have not touched it since it was built back in June of 2021.  I see the PnCConf Wizard now has firmware options to pick from.
02 Dec 2023 17:39 #287034 by PCW
Replied by PCW on topic How to tell if i have a 7i96 or 7i96s
If its from 2021, its a 7I96 (first 7I96Ss's came out in 2022)
You only need different firmware if you have added a daughtercard
that needs daughtercard specific support.
  • Moderator
  • Moderator
02 Dec 2023 18:17 #287040 by tommylight
Replied by tommylight on topic How to tell if i have a 7i96 or 7i96s
No double posting.
Now we have to sort out how to delete one of the topics as both have the same tittle and normally it will delete both.
Time to create page: 0.133 seconds
