LinuxCNC not connecting to 7i96S on 2.9.1
2 years 10 months ago #288707 by rowow
also thats my wireless connection. My ethernet connection to my mesa card is enp1s0. I disabled my wireless connection for privacy.
2 years 10 months ago #288709 by PCW
It may be that the ChromeBox is not suitable for real time.
Here's a representative ping on a working system:
$ ping 10.10.10.10
PING 10.10.10.10 (10.10.10.10) 56(84) bytes of data.
64 bytes from 10.10.10.10: icmp_seq=1 ttl=64 time=0.117 ms
64 bytes from 10.10.10.10: icmp_seq=2 ttl=64 time=0.124 ms
64 bytes from 10.10.10.10: icmp_seq=3 ttl=64 time=0.118 ms
64 bytes from 10.10.10.10: icmp_seq=4 ttl=64 time=0.119 ms
64 bytes from 10.10.10.10: icmp_seq=5 ttl=64 time=0.117 ms
64 bytes from 10.10.10.10: icmp_seq=6 ttl=64 time=0.119 ms
64 bytes from 10.10.10.10: icmp_seq=7 ttl=64 time=0.119 ms
^C
--- 10.10.10.10 ping statistics ---
7 packets transmitted, 7 received, 0% packet loss, time 6151ms
rtt min/avg/max/mdev = 0.117/0.119/0.124/0.002 ms
2 years 10 months ago #288711 by tommylight
yup, edited my post to reflect that and to blame it on something ... :)
2 years 10 months ago #288713 by rowow
tomorrow ill try reinstalling linux with version 2.8.2, and testing it out on a raspberry pi 4. I understand my latency is worse than what you showed but only by 3-4x. I hope that linuxcnc would have some tolerance without freaking out over a small difference? at least to connect and start the program.
2 years 10 months ago #288716 by PCW
I'm not sure what the exact problem is, but a PC that has no
access to power management setup is not likely to be a good
candidate for running LinuxCNC (It would be similar to a laptop
which are also not suggested for hosting LinuxCNC)
The "resource unavailable" error might also indicate loss of link
So checking the yellow link LED on the 7I96S's RJ45 connector
when you get the error might be worth a shot
2 years 10 months ago #288719 by rowow
Are mini PCs suitable to run Linux cnc? Anything I should look for specifically? I like to keep my computers running most of the day so having it small helps a lot. Would the following work?
HP EliteDesk 800 G2 Desktop Mini Business PC, Intel Quad-Core i5-6500T up to 3.1G,16G DDR4,240G SSD,VGA,DP,Win 10 Pro 64 bit
a.co/d/h4FURtk
Time to create page: 0.486 seconds
