LinuxCNC not connecting to 7i96S on 2.9.1
2 years 10 months ago #288691 by rowow
Did "sudo ethtool -C enp1s0 rx-usecs 0" no output,
Still error when starting linux cnc
Print file information: RUN_IN_PLACE=no LINUXCNC_DIR= LINUXCNC_BIN_DIR=/usr/bin LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc LINUXCNC_SCRIPT_DIR= LINUXCNC_RTLIB_DIR=/usr/lib/linuxcnc/modules LINUXCNC_CONFIG_DIR= LINUXCNC_LANG_DIR=/usr/lib/tcltk/linuxcnc/msgs INIVAR=inivar HALCMD=halcmd LINUXCNC_EMCSH=/usr/bin/wish8.6 LINUXCNC - 2.9.1 Machine configuration directory is '/home/rowow/linuxcnc/configs/Mill' Machine configuration file is 'Mill.ini' INIFILE=/home/rowow/linuxcnc/configs/Mill/Mill.ini VERSION=1.1 PARAMETER_FILE=linuxcnc.var TPMOD= HOMEMOD= TASK=milltask HALUI=halui DISPLAY=gmoccapy COORDINATES=XYZ KINEMATICS=trivkins coordinates=XYZ Starting LinuxCNC... Starting LinuxCNC server program: linuxcncsvr Loading Real Time OS, RTAPI, and HAL_LIB modules Starting LinuxCNC IO program: io Starting HAL User Interface program: halui linuxcnc TPMOD=tpmod HOMEMOD=homemod EMCMOT=motmod Found file(REL): ./Mill.hal Shutting down and cleaning up LinuxCNC... Running HAL shutdown script hm2: loading Mesa HostMot2 driver version 0.15 hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2 hm2_eth: 10.10.10.10: INFO: Hardware address (MAC): 00:60:1b:16:84:e8 hm2_eth: discovered 7I96S hm2/hm2_7i96s.0: Low Level init 0.15 hm2/hm2_7i96s.0: Smart Serial Firmware Version 43 board fails HM2 registration hm2_eth: in hm2_eth_reset hm2: unloading Removing HAL_LIB, RTAPI, and Real Time OS modules Removing NML shared memory segments Debug file information: Note: Using POSIX realtime hm2_eth: rtapi_app_main: Resource temporarily unavailable (-11) ./Mill.hal:9: waitpid failed /usr/bin/rtapi_app hm2_eth ./Mill.hal:9: /usr/bin/rtapi_app exited without becoming ready ./Mill.hal:9: insmod for hm2_eth failed, returned -1 2930 Stopping realtime threads Unloading hal components Note: Using POSIX realtime
2 years 10 months ago #288692 by PCW
Did the ping times improve?
What is your servo thread period?
2 years 10 months ago #288693 by rowow
Ping times did not improve.
Attached servo thread jitter screenshot
2 years 10 months ago - 2 years 10 months ago #288694 by PCW
What is LinuxCNC's servo thread period?
If the ping times did not improve,  there is something preventing good
Ethernet latency. What is the host machine hardware?
Last edit: 2 years 10 months ago by PCW.
2 years 10 months ago #288696 by rowow
im using a chrome box acer CX12. im not sure the exact ethernet hardware on the device.
2 years 10 months ago - 2 years 10 months ago #288697 by PCW
Have you disabled all power management options in the BIOS?
You might try a longer servo thread period
Time to create page: 0.392 seconds
