- Thank you received: 5334
requesting help with 7i80DB-16 and C10 breakout board
2 years 9 months ago #291563
Replied by PCW on topic requesting help with 7i80DB-16 and C10 breakout board
I copy-pasted it from your hal file.
- gbsd86
2 years 9 months ago - 2 years 9 months ago #291630
by gbsd86
Replied by gbsd86 on topic requesting help with 7i80DB-16 and C10 breakout board
Appoligies for that. I looked for that line, did a search. Missed it somehow.
Took that line out. Now:
/GrizzlyNu.hal:55: parameter or pin 'hm2_7i80.0.stepgen.01.dirsetup' not found
Last edit: 2 years 9 months ago by gbsd86. Reason: add files
2 years 9 months ago #291633
Yes, that's because the firmware currently installed
in the 7I80DB-16 has no stepgen hardware
(it looks like a configuration for 4x7I77s)
What daughterboard are you using with the 7I80DB?
This determines the appropriate firmware so the
7I80DB pinout matches your daughterboard.
- gbsd86
2 years 9 months ago #291634
by gbsd86
PnCConf lists 7I80DB - internal data
7I76x2 is the only selection
I am trying to duplicate my parallel port pin to avoid rewiring.
I have not loaded a bit file into the board. I assumed the PnCConf software did that.
Under the assumption the 7I80DB could be configured the same as the parallel port,
I am not using a daughter board, using a C10 breakout board: FEATURES:
- IEEE 1284 Standard compatible.
- PULL-UP or PULL-DOWN selection for inputs.
- Buffered inputs and outputs.
- Bidirectional pins 2-9.
- Output pins 1, 2, 3, 4, 5, 6, 7, 8, 9, 14, 16, 17. Or 1, 14, 16, 17.
- Input pins 10, 11, 12, 13, 15. Or 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 15.
- Input and output pins with the close-by ground or +5vdc connections
- External Enable Pin (EN).
- Works directly with popular CNC hardware and software.
- All TTL 5VDC signals.
- Screw-On connections for all terminals.
- Status LEDs for enable.
2 years 9 months ago #291635
7i80db_16_mx4660x2D.bit
7i80db_16_Benezanx2.bit
Are two existing firmware imaged for the 7I80DB-16
which have parallel port compatible pinouts and include stepgens
These would need to be written to the 7I80DB-16 with mesaflash
pncconf should be able to make a decent config for this but I would
probably select 7I92 + G540x2 and then edit the ini file to change the
card name from 7I92 to 7I80
- gbsd86
2 years 9 months ago #291670
by gbsd86
I loaded 7i80db_16_mx4660x2D.bit
Had to disable the pwm lines. Error file said it could not find the pwm.
After that LinuxCNC will open. Haven't tried to connect to the breakout board.
Not sure how to connect the dots between the physical pins and the hal file.
Time to create page: 0.463 seconds
