- Configuring LinuxCNC
- Configuration Tools
- PnCConf Wizard
- 7i96s + 7i89 analog spindle and mpg troubles
- Thank you received: 5316
01 Jun 2024 22:27 #302113
Replied by PCW on topic 7i96s + 7i89 analog spindle and mpg troubles
I'd probably leave it in custom.hal since that has almost
all the mpg connections
(and perhaps rename custom.hal to mpg.hal or some such)
The following user(s) said Thank You: JohnnyBeluga
- JohnnyBeluga
02 Jun 2024 06:50 #302124
by JohnnyBeluga
Replied by JohnnyBeluga on topic 7i96s + 7i89 analog spindle and mpg troubles
I'll do so and change the [hal] section in the ini file. Is there any tool to help me log/monitor physical pin and/or functions like "axis.x.jog-counts
" to try do undestand why it's not working ?
- Thank you received: 7465
02 Jun 2024 12:08 #302141
Replied by tommylight on topic 7i96s + 7i89 analog spindle and mpg troubles
Machine menu, show hal configuration, on the left side choose pins and on the right side you can see values and LED's for those pins and parameters.
- JohnnyBeluga
02 Jun 2024 18:25 #302183
by JohnnyBeluga
Thank you, very nice tool. At least I'm confident with my hardware now. I managed to verify all my MPG signals and everything seems fine. The MPG-axis is enabled when it should be, the scale is correct, and the axis jog count increments. However, the axis doesn't move. It works when I use Gmoccapy, and motion.jog-is-active goes to true, but not with the MPG. Sorry to ask so many questions, but if you can give me some hints about where to look, it would be greatly appreciated. I think there is a missing link somewhere, and I'm struggling to find it
02 Jun 2024 18:50 #302187
Sorry but i do not use GmoccaPY, i build/use plasma machines and some small scratchers/engravers, and need badly to finish building a mill as parts keep rusting.
- JohnnyBeluga
02 Jun 2024 19:53 #302193
by JohnnyBeluga
The problem was very simple, my machine was not homed. ^_^'
02 Jun 2024 21:39 - 02 Jun 2024 21:40 #302198
You can jog before homing if required.
This requires duplicating the axis jog connections
with similar joint connections.
That is, Axis jog enable and count inputs are not
active until homed, but joint inputs are active before
homing is done.
homing is done.
Last edit: 02 Jun 2024 21:40 by PCW.
- PnCConf Wizard
Time to create page: 0.290 seconds
