I have a small robot arm that I am attempting to control with LinuxCNC. Ultimately, I would live to have full IK... but for now just being able to control it is fine. I used the PnCConf Wizard and even though all 4 axis are rotary... the best I could do was an XYZA configuration... it works... I can program the robot and tinker. Great.
Now I am trying to add a 5th axis. I have a cross-slide so the robot arm can move side to side. I made a copy of the X-Axis and renamed it to the U-AXIS. I then went in and changed it from AXIS-0 to AXIS-4, changes all the other "stuff" from "X" to "U" which worked fine when I did it on a parallel port machine in my murky past.
But this... it has a failure and I just can't figure it out.
Anyone here able to see what the issue is... I'm simply not seeing it.
Error List (Debug Output)
Working 4-Axis Files
Failing 5-Axis Files
Thanks in advance,
Jerry
