how to solve this..i also get sometimes joint 0/1 not following error
2 years 3 months ago #304439 by Aswin
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.2
Machine configuration directory is '/home/aswin/linuxcnc/configs/my_LinuxCNC_machine'
Machine configuration file is 'my_LinuxCNC_machine.ini'
INIFILE=/home/aswin/linuxcnc/configs/my_LinuxCNC_machine/my_LinuxCNC_machine.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=gmoccapy
COORDINATES=XYZ
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
Found file(REL): ./my_LinuxCNC_machine.hal
Running HAL shutdown script
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: ERROR: Could not retrieve hardware address (MAC) of 10.10.10.1: Connection refused
hm2: unloading
Debug file information:
Note: Using POSIX realtime
hm2_eth: rtapi_app_main: Connection refused (-111)
./my_LinuxCNC_machine.hal:9: waitpid failed /usr/bin/rtapi_app hm2_eth
./my_LinuxCNC_machine.hal:9: /usr/bin/rtapi_app exited without becoming ready
./my_LinuxCNC_machine.hal:9: insmod for hm2_eth failed, returned -1
5811
Stopping realtime threads
Unloading hal components
2 years 3 months ago #304475 by PCW
Wrong IP address for the Mesa card (unless you changed it)
Time to create page: 0.061 seconds
