7i96s with 7i76 on P2
- fat238sg
25 Aug 2024 04:32 #308573
by fat238sg
7i96s with 7i76 on P2 was created by fat238sg
Hi guys!
I was trying to setup a new configuration for 7i96s with a 7i76 but faced some issues trying to go thru with the PNCCONF. previously i was on a old computer with 5i25 and 7i76 but i had to change it to a 7i96s and i was hoping not the touch any wiring on the existing 7i76.
is anyone able to tell me what is the exact error and how can i go about the debug it?
i have attached the hal and ini files here.
Thanks so much!
hm2/hm2_7i96s.0: config.num_stepgens=10, but only 5 are available, not loading driver
hm2/hm2_7i96s.0: failed to parse Module Descriptor 5
hm2_eth: rtapi_app_main: Invalid argument (-22)
./Waterjet.hal:10: waitpid failed /usr/bin/rtapi_app hm2_eth
./Waterjet.hal:10: /usr/bin/rtapi_app exited without becoming ready
./Waterjet.hal:10: insmod for hm2_eth failed, returned -1
Thanks so much!
- fat238sg
25 Aug 2024 09:05 #308585
by fat238sg
Replied by fat238sg on topic 7i96s with 7i76 on P2
i made it work already, somehow it could see 10 stepgens and after modification of the hal file to read stepgen 05 and 06 instead of 00 and 01 previous, now the axis servos can run, but i am still unable to get the outputs to work.
Anyone able to let me know in a 7i96s + 7i76 config, what hal label will output 0 on the 7i76 be on linuxcnc?
- Thank you received: 5329
25 Aug 2024 13:40 #308598
You can check the I/O pin mapping by running:
mesaflash --device 7I96S --addr [card_ip_address] -dbname3 7i76 --readhmid
Replied by PCW on topic 7i96s with 7i76 on P2
It will be on sserial channel 1i made it work already, somehow it could see 10 stepgens and after modification of the hal file to read stepgen 05 and 06 instead of 00 and 01 previous, now the axis servos can run, but i am still unable to get the outputs to work.
