6i25 and 7i77 , what am I doing wrong?
- vibram
I have a 6i25 flashed with firmware 5i25_7i77x2
5i25 W1 ,W2, W3, W4 are up
7i77 W5, W1, W4,W12 left handed,
CR1, CR6 and CR7 are yellow, no other LED turned on
loadrt hm2_pci output:
hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
hm2_pci: discovered 5i25 at 0000:02:00.0
hm2/hm2_5i25.0: Low Level init 0.15
hm2/hm2_5i25.0: Smart Serial Firmware Version 43
Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
hm2/hm2_5i25.0: 34 I/O Pins used:
hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin tx1 (Output)
hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin rx1 (Input)
hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
hm2/hm2_5i25.0: IO Pin 024 (P2-17): Muxed Encoder Select #6, pin Mux Select 0 (Output)
hm2/hm2_5i25.0: IO Pin 025 (P2-05): Muxed Encoder #3, pin Muxed A (Input)
hm2/hm2_5i25.0: IO Pin 026 (P2-06): Muxed Encoder #3, pin Muxed B (Input)
hm2/hm2_5i25.0: IO Pin 027 (P2-07): Muxed Encoder #3, pin Muxed Index (Input)
hm2/hm2_5i25.0: IO Pin 028 (P2-08): Muxed Encoder #4, pin Muxed A (Input)
hm2/hm2_5i25.0: IO Pin 029 (P2-09): Muxed Encoder #4, pin Muxed B (Input)
hm2/hm2_5i25.0: IO Pin 030 (P2-10): Muxed Encoder #4, pin Muxed Index (Input)
hm2/hm2_5i25.0: IO Pin 031 (P2-11): Muxed Encoder #5, pin Muxed A (Input)
hm2/hm2_5i25.0: IO Pin 032 (P2-12): Muxed Encoder #5, pin Muxed B (Input)
hm2/hm2_5i25.0: IO Pin 033 (P2-13): Muxed Encoder #5, pin Muxed Index (Input)
hm2/hm2_5i25.0: registered
show pin output:omponent Pins:
Owner Type Dir Value Name
11 s32 OUT 0 hm2_5i25.0.0.debug
11 bit IN FALSE hm2_5i25.0.7i77.0.1.analogena
11 float IN 0 hm2_5i25.0.7i77.0.1.analogout0
11 float IN 0 hm2_5i25.0.7i77.0.1.analogout1
11 float IN 0 hm2_5i25.0.7i77.0.1.analogout2
11 float IN 0 hm2_5i25.0.7i77.0.1.analogout3
11 float IN 0 hm2_5i25.0.7i77.0.1.analogout4
11 float IN 0 hm2_5i25.0.7i77.0.1.analogout5
11 bit IN FALSE hm2_5i25.0.7i77.0.1.spinena
11 s32 OUT 0 hm2_5i25.0.encoder.00.count
11 s32 OUT 0 hm2_5i25.0.encoder.00.count-latched
11 bit I/O FALSE hm2_5i25.0.encoder.00.index-enable
11 bit OUT TRUE hm2_5i25.0.encoder.00.input-a
11 bit OUT FALSE hm2_5i25.0.encoder.00.input-b
11 bit OUT TRUE hm2_5i25.0.encoder.00.input-index
11 float OUT 0 hm2_5i25.0.encoder.00.position
11 float OUT 0 hm2_5i25.0.encoder.00.position-latched
11 bit OUT FALSE hm2_5i25.0.encoder.00.quad-error
11 bit IN FALSE hm2_5i25.0.encoder.00.quad-error-enable
11 s32 OUT 1 hm2_5i25.0.encoder.00.rawcounts
11 s32 OUT 1 hm2_5i25.0.encoder.00.rawlatch
11 bit IN FALSE hm2_5i25.0.encoder.00.reset
11 float OUT 0 hm2_5i25.0.encoder.00.velocity
11 float OUT 0 hm2_5i25.0.encoder.00.velocity-rpm
11 s32 OUT 0 hm2_5i25.0.encoder.01.count
11 s32 OUT 0 hm2_5i25.0.encoder.01.count-latched
11 bit I/O FALSE hm2_5i25.0.encoder.01.index-enable
11 bit OUT FALSE hm2_5i25.0.encoder.01.input-a
11 bit OUT TRUE hm2_5i25.0.encoder.01.input-b
11 bit OUT FALSE hm2_5i25.0.encoder.01.input-index
11 float OUT 0 hm2_5i25.0.encoder.01.position
11 float OUT 0 hm2_5i25.0.encoder.01.position-latched
11 bit OUT FALSE hm2_5i25.0.encoder.01.quad-error
11 bit IN FALSE hm2_5i25.0.encoder.01.quad-error-enable
11 s32 OUT 65535 hm2_5i25.0.encoder.01.rawcounts
11 s32 OUT 65535 hm2_5i25.0.encoder.01.rawlatch
11 bit IN FALSE hm2_5i25.0.encoder.01.reset
11 float OUT 0 hm2_5i25.0.encoder.01.velocity
11 float OUT 0 hm2_5i25.0.encoder.01.velocity-rpm
11 s32 OUT 0 hm2_5i25.0.encoder.02.count
11 s32 OUT 0 hm2_5i25.0.encoder.02.count-latched
11 bit I/O FALSE hm2_5i25.0.encoder.02.index-enable
11 bit OUT FALSE hm2_5i25.0.encoder.02.input-a
11 bit OUT TRUE hm2_5i25.0.encoder.02.input-b
11 bit OUT FALSE hm2_5i25.0.encoder.02.input-index
11 float OUT 0 hm2_5i25.0.encoder.02.position
11 float OUT 0 hm2_5i25.0.encoder.02.position-latched
11 bit OUT FALSE hm2_5i25.0.encoder.02.quad-error
11 bit IN FALSE hm2_5i25.0.encoder.02.quad-error-enable
11 s32 OUT 65535 hm2_5i25.0.encoder.02.rawcounts
11 s32 OUT 65535 hm2_5i25.0.encoder.02.rawlatch
11 bit IN FALSE hm2_5i25.0.encoder.02.reset
11 float OUT 0 hm2_5i25.0.encoder.02.velocity
11 float OUT 0 hm2_5i25.0.encoder.02.velocity-rpm
11 s32 OUT 0 hm2_5i25.0.encoder.03.count
11 s32 OUT 0 hm2_5i25.0.encoder.03.count-latched
11 bit I/O FALSE hm2_5i25.0.encoder.03.index-enable
11 bit OUT FALSE hm2_5i25.0.encoder.03.input-a
11 bit OUT FALSE hm2_5i25.0.encoder.03.input-b
11 bit OUT TRUE hm2_5i25.0.encoder.03.input-index
11 float OUT 0 hm2_5i25.0.encoder.03.position
11 float OUT 0 hm2_5i25.0.encoder.03.position-latched
11 bit OUT FALSE hm2_5i25.0.encoder.03.quad-error
11 bit IN FALSE hm2_5i25.0.encoder.03.quad-error-enable
11 s32 OUT 0 hm2_5i25.0.encoder.03.rawcounts
11 s32 OUT 0 hm2_5i25.0.encoder.03.rawlatch
11 bit IN FALSE hm2_5i25.0.encoder.03.reset
11 float OUT 0 hm2_5i25.0.encoder.03.velocity
11 float OUT 0 hm2_5i25.0.encoder.03.velocity-rpm
11 s32 OUT 0 hm2_5i25.0.encoder.04.count
11 s32 OUT 0 hm2_5i25.0.encoder.04.count-latched
11 bit I/O FALSE hm2_5i25.0.encoder.04.index-enable
11 bit OUT TRUE hm2_5i25.0.encoder.04.input-a
11 bit OUT FALSE hm2_5i25.0.encoder.04.input-b
11 bit OUT TRUE hm2_5i25.0.encoder.04.input-index
11 float OUT 0 hm2_5i25.0.encoder.04.position
11 float OUT 0 hm2_5i25.0.encoder.04.position-latched
11 bit OUT FALSE hm2_5i25.0.encoder.04.quad-error
11 bit IN FALSE hm2_5i25.0.encoder.04.quad-error-enable
11 s32 OUT 1 hm2_5i25.0.encoder.04.rawcounts
11 s32 OUT 1 hm2_5i25.0.encoder.04.rawlatch
11 bit IN FALSE hm2_5i25.0.encoder.04.reset
11 float OUT 0 hm2_5i25.0.encoder.04.velocity
11 float OUT 0 hm2_5i25.0.encoder.04.velocity-rpm
11 s32 OUT 0 hm2_5i25.0.encoder.05.count
11 s32 OUT 0 hm2_5i25.0.encoder.05.count-latched
11 bit I/O FALSE hm2_5i25.0.encoder.05.index-enable
11 bit OUT TRUE hm2_5i25.0.encoder.05.input-a
11 bit OUT FALSE hm2_5i25.0.encoder.05.input-b
11 bit OUT TRUE hm2_5i25.0.encoder.05.input-index
11 float OUT 0 hm2_5i25.0.encoder.05.position
11 float OUT 0 hm2_5i25.0.encoder.05.position-latched
11 bit OUT FALSE hm2_5i25.0.encoder.05.quad-error
11 bit IN FALSE hm2_5i25.0.encoder.05.quad-error-enable
11 s32 OUT 1 hm2_5i25.0.encoder.05.rawcounts
11 s32 OUT 1 hm2_5i25.0.encoder.05.rawlatch
11 bit IN FALSE hm2_5i25.0.encoder.05.reset
11 float OUT 0 hm2_5i25.0.encoder.05.velocity
11 float OUT 0 hm2_5i25.0.encoder.05.velocity-rpm
11 s32 OUT 0 hm2_5i25.0.encoder.06.count
11 s32 OUT 0 hm2_5i25.0.encoder.06.count-latched
11 bit I/O FALSE hm2_5i25.0.encoder.06.index-enable
11 bit OUT TRUE hm2_5i25.0.encoder.06.input-a
11 bit OUT TRUE hm2_5i25.0.encoder.06.input-b
11 bit OUT FALSE hm2_5i25.0.encoder.06.input-index
11 float OUT 0 hm2_5i25.0.encoder.06.position
11 float OUT 0 hm2_5i25.0.encoder.06.position-latched
11 bit OUT FALSE hm2_5i25.0.encoder.06.quad-error
11 bit IN FALSE hm2_5i25.0.encoder.06.quad-error-enable
11 s32 OUT 0 hm2_5i25.0.encoder.06.rawcounts
11 s32 OUT 0 hm2_5i25.0.encoder.06.rawlatch
11 bit IN FALSE hm2_5i25.0.encoder.06.reset
11 float OUT 0 hm2_5i25.0.encoder.06.velocity
11 float OUT 0 hm2_5i25.0.encoder.06.velocity-rpm
11 s32 OUT 0 hm2_5i25.0.encoder.07.count
11 s32 OUT 0 hm2_5i25.0.encoder.07.count-latched
11 bit I/O FALSE hm2_5i25.0.encoder.07.index-enable
11 bit OUT TRUE hm2_5i25.0.encoder.07.input-a
11 bit OUT TRUE hm2_5i25.0.encoder.07.input-b
11 bit OUT FALSE hm2_5i25.0.encoder.07.input-index
11 float OUT 0 hm2_5i25.0.encoder.07.position
11 float OUT 0 hm2_5i25.0.encoder.07.position-latched
11 bit OUT FALSE hm2_5i25.0.encoder.07.quad-error
11 bit IN FALSE hm2_5i25.0.encoder.07.quad-error-enable
11 s32 OUT 0 hm2_5i25.0.encoder.07.rawcounts
11 s32 OUT 0 hm2_5i25.0.encoder.07.rawlatch
11 bit IN FALSE hm2_5i25.0.encoder.07.reset
11 float OUT 0 hm2_5i25.0.encoder.07.velocity
11 float OUT 0 hm2_5i25.0.encoder.07.velocity-rpm
11 s32 OUT 0 hm2_5i25.0.encoder.08.count
11 s32 OUT 0 hm2_5i25.0.encoder.08.count-latched
11 bit I/O FALSE hm2_5i25.0.encoder.08.index-enable
11 bit OUT TRUE hm2_5i25.0.encoder.08.input-a
11 bit OUT TRUE hm2_5i25.0.encoder.08.input-b
11 bit OUT FALSE hm2_5i25.0.encoder.08.input-index
11 float OUT 0 hm2_5i25.0.encoder.08.position
11 float OUT 0 hm2_5i25.0.encoder.08.position-latched
11 bit OUT FALSE hm2_5i25.0.encoder.08.quad-error
11 bit IN FALSE hm2_5i25.0.encoder.08.quad-error-enable
11 s32 OUT 0 hm2_5i25.0.encoder.08.rawcounts
11 s32 OUT 0 hm2_5i25.0.encoder.08.rawlatch
11 bit IN FALSE hm2_5i25.0.encoder.08.reset
11 float OUT 0 hm2_5i25.0.encoder.08.velocity
11 float OUT 0 hm2_5i25.0.encoder.08.velocity-rpm
11 s32 OUT 0 hm2_5i25.0.encoder.09.count
11 s32 OUT 0 hm2_5i25.0.encoder.09.count-latched
11 bit I/O FALSE hm2_5i25.0.encoder.09.index-enable
11 bit OUT TRUE hm2_5i25.0.encoder.09.input-a
11 bit OUT TRUE hm2_5i25.0.encoder.09.input-b
11 bit OUT FALSE hm2_5i25.0.encoder.09.input-index
11 float OUT 0 hm2_5i25.0.encoder.09.position
11 float OUT 0 hm2_5i25.0.encoder.09.position-latched
11 bit OUT FALSE hm2_5i25.0.encoder.09.quad-error
11 bit IN FALSE hm2_5i25.0.encoder.09.quad-error-enable
11 s32 OUT 0 hm2_5i25.0.encoder.09.rawcounts
11 s32 OUT 0 hm2_5i25.0.encoder.09.rawlatch
11 bit IN FALSE hm2_5i25.0.encoder.09.reset
11 float OUT 0 hm2_5i25.0.encoder.09.velocity
11 float OUT 0 hm2_5i25.0.encoder.09.velocity-rpm
11 s32 OUT 0 hm2_5i25.0.encoder.10.count
11 s32 OUT 0 hm2_5i25.0.encoder.10.count-latched
11 bit I/O FALSE hm2_5i25.0.encoder.10.index-enable
11 bit OUT TRUE hm2_5i25.0.encoder.10.input-a
11 bit OUT TRUE hm2_5i25.0.encoder.10.input-b
11 bit OUT FALSE hm2_5i25.0.encoder.10.input-index
11 float OUT 0 hm2_5i25.0.encoder.10.position
11 float OUT 0 hm2_5i25.0.encoder.10.position-latched
11 bit OUT FALSE hm2_5i25.0.encoder.10.quad-error
11 bit IN FALSE hm2_5i25.0.encoder.10.quad-error-enable
11 s32 OUT 0 hm2_5i25.0.encoder.10.rawcounts
11 s32 OUT 0 hm2_5i25.0.encoder.10.rawlatch
11 bit IN FALSE hm2_5i25.0.encoder.10.reset
11 float OUT 0 hm2_5i25.0.encoder.10.velocity
11 float OUT 0 hm2_5i25.0.encoder.10.velocity-rpm
11 s32 OUT 0 hm2_5i25.0.encoder.11.count
11 s32 OUT 0 hm2_5i25.0.encoder.11.count-latched
11 bit I/O FALSE hm2_5i25.0.encoder.11.index-enable
11 bit OUT TRUE hm2_5i25.0.encoder.11.input-a
11 bit OUT TRUE hm2_5i25.0.encoder.11.input-b
11 bit OUT FALSE hm2_5i25.0.encoder.11.input-index
11 float OUT 0 hm2_5i25.0.encoder.11.position
11 float OUT 0 hm2_5i25.0.encoder.11.position-latched
11 bit OUT FALSE hm2_5i25.0.encoder.11.quad-error
11 bit IN FALSE hm2_5i25.0.encoder.11.quad-error-enable
11 s32 OUT 0 hm2_5i25.0.encoder.11.rawcounts
11 s32 OUT 0 hm2_5i25.0.encoder.11.rawlatch
11 bit IN FALSE hm2_5i25.0.encoder.11.reset
11 float OUT 0 hm2_5i25.0.encoder.11.velocity
11 float OUT 0 hm2_5i25.0.encoder.11.velocity-rpm
11 bit IN FALSE hm2_5i25.0.encoder.hires-timestamp
11 u32 IN 0x007F2815 hm2_5i25.0.encoder.muxed-sample-frequency
11 bit OUT TRUE hm2_5i25.0.gpio.000.in
11 bit OUT FALSE hm2_5i25.0.gpio.000.in_not
11 bit IN FALSE hm2_5i25.0.gpio.000.out
11 bit OUT TRUE hm2_5i25.0.gpio.001.in
11 bit OUT FALSE hm2_5i25.0.gpio.001.in_not
11 bit IN FALSE hm2_5i25.0.gpio.001.out
11 bit OUT TRUE hm2_5i25.0.gpio.002.in
11 bit OUT FALSE hm2_5i25.0.gpio.002.in_not
11 bit IN FALSE hm2_5i25.0.gpio.002.out
11 bit OUT TRUE hm2_5i25.0.gpio.003.in
11 bit OUT FALSE hm2_5i25.0.gpio.003.in_not
11 bit OUT TRUE hm2_5i25.0.gpio.004.in
11 bit OUT FALSE hm2_5i25.0.gpio.004.in_not
11 bit OUT TRUE hm2_5i25.0.gpio.005.in
11 bit OUT FALSE hm2_5i25.0.gpio.005.in_not
11 bit IN FALSE hm2_5i25.0.gpio.005.out
11 bit OUT FALSE hm2_5i25.0.gpio.006.in
11 bit OUT TRUE hm2_5i25.0.gpio.006.in_not
11 bit IN FALSE hm2_5i25.0.gpio.006.out
11 bit OUT FALSE hm2_5i25.0.gpio.007.in
11 bit OUT TRUE hm2_5i25.0.gpio.007.in_not
11 bit OUT TRUE hm2_5i25.0.gpio.008.in
11 bit OUT FALSE hm2_5i25.0.gpio.008.in_not
11 bit OUT FALSE hm2_5i25.0.gpio.009.in
11 bit OUT TRUE hm2_5i25.0.gpio.009.in_not
11 bit OUT FALSE hm2_5i25.0.gpio.010.in
11 bit OUT TRUE hm2_5i25.0.gpio.010.in_not
11 bit OUT FALSE hm2_5i25.0.gpio.011.in
11 bit OUT TRUE hm2_5i25.0.gpio.011.in_not
11 bit OUT TRUE hm2_5i25.0.gpio.012.in
11 bit OUT FALSE hm2_5i25.0.gpio.012.in_not
11 bit OUT TRUE hm2_5i25.0.gpio.013.in
11 bit OUT FALSE hm2_5i25.0.gpio.013.in_not
11 bit OUT TRUE hm2_5i25.0.gpio.014.in
11 bit OUT FALSE hm2_5i25.0.gpio.014.in_not
11 bit OUT FALSE hm2_5i25.0.gpio.015.in
11 bit OUT TRUE hm2_5i25.0.gpio.015.in_not
11 bit OUT FALSE hm2_5i25.0.gpio.016.in
11 bit OUT TRUE hm2_5i25.0.gpio.016.in_not
11 bit OUT TRUE hm2_5i25.0.gpio.017.in
11 bit OUT FALSE hm2_5i25.0.gpio.017.in_not
11 bit IN FALSE hm2_5i25.0.gpio.017.out
11 bit OUT TRUE hm2_5i25.0.gpio.018.in
11 bit OUT FALSE hm2_5i25.0.gpio.018.in_not
11 bit IN FALSE hm2_5i25.0.gpio.018.out
11 bit OUT TRUE hm2_5i25.0.gpio.019.in
11 bit OUT FALSE hm2_5i25.0.gpio.019.in_not
11 bit IN FALSE hm2_5i25.0.gpio.019.out
11 bit OUT TRUE hm2_5i25.0.gpio.020.in
11 bit OUT FALSE hm2_5i25.0.gpio.020.in_not
11 bit IN FALSE hm2_5i25.0.gpio.020.out
11 bit OUT TRUE hm2_5i25.0.gpio.021.in
11 bit OUT FALSE hm2_5i25.0.gpio.021.in_not
11 bit IN FALSE hm2_5i25.0.gpio.021.out
11 bit OUT TRUE hm2_5i25.0.gpio.022.in
11 bit OUT FALSE hm2_5i25.0.gpio.022.in_not
11 bit IN FALSE hm2_5i25.0.gpio.022.out
11 bit OUT TRUE hm2_5i25.0.gpio.023.in
11 bit OUT FALSE hm2_5i25.0.gpio.023.in_not
11 bit IN FALSE hm2_5i25.0.gpio.023.out
11 bit OUT TRUE hm2_5i25.0.gpio.024.in
11 bit OUT FALSE hm2_5i25.0.gpio.024.in_not
11 bit OUT TRUE hm2_5i25.0.gpio.025.in
11 bit OUT FALSE hm2_5i25.0.gpio.025.in_not
11 bit OUT TRUE hm2_5i25.0.gpio.026.in
11 bit OUT FALSE hm2_5i25.0.gpio.026.in_not
11 bit OUT TRUE hm2_5i25.0.gpio.027.in
11 bit OUT FALSE hm2_5i25.0.gpio.027.in_not
11 bit OUT TRUE hm2_5i25.0.gpio.028.in
11 bit OUT FALSE hm2_5i25.0.gpio.028.in_not
11 bit OUT TRUE hm2_5i25.0.gpio.029.in
11 bit OUT FALSE hm2_5i25.0.gpio.029.in_not
11 bit OUT TRUE hm2_5i25.0.gpio.030.in
11 bit OUT FALSE hm2_5i25.0.gpio.030.in_not
11 bit OUT TRUE hm2_5i25.0.gpio.031.in
11 bit OUT FALSE hm2_5i25.0.gpio.031.in_not
11 bit OUT TRUE hm2_5i25.0.gpio.032.in
11 bit OUT FALSE hm2_5i25.0.gpio.032.in_not
11 bit OUT TRUE hm2_5i25.0.gpio.033.in
11 bit OUT FALSE hm2_5i25.0.gpio.033.in_not
11 bit IN FALSE hm2_5i25.0.led.CR01
11 bit IN FALSE hm2_5i25.0.led.CR02
11 s32 OUT 0 hm2_5i25.0.read.time
11 s32 OUT 0 hm2_5i25.0.read_gpio.time
11 u32 OUT 0x00000000 hm2_5i25.0.sserial.port-0.fault-count
11 u32 OUT 0x00000000 hm2_5i25.0.sserial.port-0.port_state
11 u32 OUT 0x00000000 hm2_5i25.0.sserial.port-0.port_state2
11 u32 OUT 0x00000000 hm2_5i25.0.sserial.port-0.port_state3
11 bit IN TRUE hm2_5i25.0.sserial.port-0.run
11 bit I/O FALSE hm2_5i25.0.watchdog.has_bit
11 s32 OUT 0 hm2_5i25.0.write.time
11 s32 OUT 0 hm2_5i25.0.write_gpio.time
5 s32 OUT 0 th.time
Is it normal to only have 7i77 analog output and all gpio under 5i25 ?I'm a bit lost
Thank you
- Thank you received: 5329
probably because there is no field power applied (orange connector)
- vibram
Thank you for your help.
When I try to run LinuxCNC with the specified Mill profile (Hal included)
I get the following error:
Debug file information:
Note: Using POSIX realtime
Linux parallel port 0 not found
hal_parport: rtapi_app_main: No such file or directory (-2)
./Mill.hal:9: waitpid failed /usr/bin/rtapi_app hal_parport
./Mill.hal:9: /usr/bin/rtapi_app exited without becoming ready
./Mill.hal:9: insmod for hal_parport failed, returned -1
43383
Stopping realtime threads
Unloading hal components
