7i76E Spindle configuration
1 year 1 month ago #334977 by RobotMatic
I can't configure the spindle, the configuration screen doesn't appear.
 also can't choose the PWM signal or CW - CCW.
I am on 2.9.5 and I don't understand what I'm doing wrong.
There is something that changed, in version 2.7.15 of LinuxCNC it could be done without problems, now it is impossible for me, I don't understand what is happening, I can't find information to guide me. Thank you.!!!
1 year 1 month ago #335001 by PCW
Replied by PCW on topic 7i76E Spindle configuration
There is no PWM involved (at least at the configuration level)
pncconf setup looks like:
and:
1 year 1 month ago #335012 by RobotMatic
yes!
1 year 1 month ago - 1 year 1 month ago #335013 by RobotMatic
I can't see that page, it goes up to P1-P2.
I see only TB2/TB3 P1 P2
it doesn't allow me to add a PWM. I set it to 1 and it goes back to 0
Last edit: 1 year 1 month ago by RobotMatic.
1 year 1 month ago #335020 by PCW
I suspect this may be a localization bug in pncconf
If you run pncconf from the command line, does it print any error messages?
The following user(s) said Thank You: RobotMatic
1 year 1 month ago #335050 by RobotMatic
I can run it from the console without any problem.
Can the network configuration affect?
