7i76E Spindle configuration
1 year 1 month ago #335052 by PCW
Replied by PCW on topic 7i76E Spindle configuration
Can the network configuration affect?
No, the FPGA card need not even be present for pncconf to run
I would try setting the locale to en-US
The following user(s) said Thank You: RobotMatic
1 year 1 month ago #335061 by RobotMatic
Could someone set up a 4 axis + 1 spindle of 24000 rpm with pncconf?
I assembled 2 computers with 2 7i76e motherboard boards and both are experiencing the same issue.
I can program manually with cw cww enable and it works perfectly, but when I want to incorporate a pwm component, it gives me an error.
If I can obtain the .hal and .ini files, I can modify them and proceed with a machine that I need to get working.
thank you!!!!!!
1 year 1 month ago #335068 by PCW
Here's a pncconf created basic 4 axis configuration with spindle:
File Name: 7i76e-test.zip
File Size:25.93 KB
1 year 1 month ago #335089 by RobotMatic
Thank you very much!!!!!
1 year 1 month ago #335091 by RobotMatic
Houston !!! i have a problem!!!
1 year 1 month ago #335095 by tommylight
Is the networking set up for Mesa?
Is the IP address on the board set same as in the config?
Time to create page: 0.383 seconds
