Quick sanity-check
9 months 4 weeks ago #340975 by Ferra
Quick sanity-check was created by Ferra
Hi everyone,
I’m configuring LinuxCNC with a Mesa 7i95T and I’d like to ask for a quick sanity-check of my .hal and .ini files, I'm new to the subject so just to make sure I didn’t do anything stupid before I move forward.Quick context: with the 7i95T there isn’t a full “wizard” configurator. I generated a base config with PnCconf, then had to manually edit a bunch of things (I/O mapping, firmware for PWM, encoder/MPG, etc.). The machine now works, but I’d really like a second pair of eyes on:
  • Mesa pin mapping ↔ LinuxCNC signals (inputs/outputs, enables, polarity)
  • thread setup / addf order (servo-thread, base-thread if used)
  • common HAL mistakes: duplicated nets, non-existing pins, unconnected signals, wrong inversions
  • INI mistakes: JOINT/AXIS settings, limits, SCALE, stepgen/encoder params, homing sequence, etc.
I’m attaching the following:
  • machine.ini
  • machine.hal
  • if needed, I can also post all the other HAL files like postgui.hal etc
If someone can spend a couple minutes to point out anything that looks wrong or risky, I’d really appreciate it.Thanks!
9 months 3 weeks ago #340994 by jimmyrig
Replied by jimmyrig on topic Quick sanity-check
With linuxcnc mapping and io mistakes I can't tell cause it's machine dependent. A quick glance didn't pop up anything crazy.
The middle two bullet points usually work or don't. I wouldnt run the estop that way but if it works.....run it.
In this world if it works reliability and it's fast enough just let it rip.
The only thing I would recommend is to do a latency-histogram and see what your latency is. This allows for days running without issues vs hours (or min) (Applications-linuxcnc-latency histogram) If it's below 100 let it ride, below 150 prob fine might tweak a few settings, above that would tune things to make it more reliable..... Otherwise it'll studder/glitch which can cause the UI to drop out.
Let's use know and I can help tune
9 months 3 weeks ago #340999 by Ferra
Replied by Ferra on topic Quick sanity-check
Thanks a lot for your reply. I ran the latency test at the beginning of this project. At first I had some issues because of the drivers (realtek 8168), and sometimes it would stop with a “Finished reading” error. After a bit of trial and error I changed the drivers as suggested in some threads, and now it runs fine: no packet loss, and both average and maximum latency stay below 70 µs, so I think I’m good.
9 months 3 weeks ago #341044 by jimmyrig
Should be good! Run it!
Time to create page: 0.387 seconds
