MESA 6i24 + 7i36
- lukechan
- Topic Author
9 months 2 weeks ago - 9 months 2 weeks ago #341404
by lukechan
I am from Taiwan and want to modify a decommissioned laser etching machine into a CNC router. I purchased MESA 6i24 and 7i36 cards from EuSurplus. my old PC can now detect the 6i24 (5i24_16_sv8_7i36x2d.bit), and I've started configuring Pncconf.My machine and PC software configuration are as follows:
1. Linear motor: HIWIN, LMSA22
2. Driver: Maga-Fabs, D1-36-S2-2-0-00 (refer to D1-User-Manual_CN2.pdf)
3. Optical scale: Renishaw, 20μm
4. Decoder: MicroE Veratus VX 0.5μm
5. Debian 12 + Linuxcnc2.9.8 + mesa 6i24 mesa 7i36
6. X-axis travel: 500mm, maximum speed: 50mm/sec (for testing purposes only, not for actual use)The generated INI and HAL files after configuration are attached. I'm not sure that it's correct?
MESA 6i24 + 7i36 was created by lukechan
Last edit: 9 months 2 weeks ago by lukechan.
- Thank you received: 5334
9 months 2 weeks ago - 9 months 2 weeks ago #341429
Replied by PCW on topic MESA 6i24 + 7i36
3 changes should be done in the hal file:
1. Set the PWM rate to 48 KHz
2. Set offset mode true for all PWM channels:
setp hm2_5i24s.0.pwmgen.0N.offset-mode true
Where "N" is the channel number
This is critical or the analog output will be wrong
3. Set dither mode true for all PWM channels:
hm2_5i24.0.pwmgen.0N.dither true
This will increase the Analog resolution from 12 bits full scale to 15 bits full scale
Note that this requires firmware with PWMGen version 1 if the 5I24 firmware
does not have version 1 PWMGens, I will update it.
Note that you may need to change the PWM scale so you have the desired
negative feedback (control) rather than positive feedback (runaway)
Last edit: 9 months 2 weeks ago by PCW.
Time to create page: 0.441 seconds
