- Ok, setup the HOME_OFFSET to -0.118 [equivalent inch to the 0.3mm) no luck.
- Tried inverting /- latch and others.Axis has errors so attaching the image
- When attempting MACHINE / HOMING / "any single axis" I get an error message
- Home setup / limits of one [x] axis as exampleExample - output of ini for X-axis[JOINT_0]TYPE = LINEARHOME = 0.0FERROR = 10.0MIN_FERROR = 0.05MAX_VELOCITY = 3.0MAX_ACCELERATION = 2.0
current x-axis example fro ini:
[JOINT_0]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 0.05
MAX_VELOCITY = 3.0
# works - can use after home limits estop fixed - MAX_VELOCITY = 5.0
# works - can use after home limits estop fixed - MAX_ACCELERATION = 7.0
STEPGEN_MAXVEL = 6.25
STEPGEN_MAXACCEL = 8.75
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
# these are in nanoseconds
DIRSETUP = 10000
DIRHOLD = 10000
STEPLEN = 5000
STEPSPACE = 5000
STEP_SCALE = -1016.0030642800001
MIN_LIMIT = 0.0
MAX_LIMIT = 32.0
HOME_OFFSET = -0.118
HOME_SEARCH_VEL = 1.166667
HOME_LATCH_VEL = 1.066667
HOME_FINAL_VEL = 1.100000
HOME_USE_INDEX = NO
HOME_IGNORE_LIMITS = YES
HOME_SEQUENCE = 2
what worked in stepconf and parallel port
[AXIS_X]
MAX_VELOCITY = 3.25
MAX_ACCELERATION = 3.8
MIN_LIMIT = -0.25
MAX_LIMIT = 36.5
[JOINT_0]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -0.25
MAX_LIMIT = 36.5
MAX_VELOCITY = 3.25
STEPGEN_MAXACCEL = 6.0
SCALE = 1016.00000104
FERROR = 0.05
MIN_FERROR = 0.01
HOME_OFFSET = -0.750000
HOME_SEARCH_VEL = -1.100000
HOME_LATCH_VEL = -0.40000
HOME_SEQUENCE = 1
should I purchase an addon card to the 7i92TM to get the home /limits /estop working and wire direct to it?
