Is it possible to prevent the .hal file from being overwritten?
26 Sep 2026 21:26 #349910 by Holzwurm56
Is there a way to prevent the .hal file from being overwritten? If you manually edit the .hal file, everything gets overwritten by pncconf. Is there a setting to ensure that only the parts that were actually modified get overwritten in the .hal file?
Thanks,
Hans
  • rodw
  • rodw's Avatar
  • Platinum Member
  • Platinum Member
26 Sep 2026 21:29 #349912 by rodw
No, once you get a working config stop using pncconf and edit by hand.
26 Sep 2026 22:40 #349916 by tommylight
I am pretty sure MesaCT does not overwrite them, but been quite some time since i used it.
In case you want to prevent overwriting config files that are good and done with editing, you can use the file explorer and set the permissions to read only.
27 Sep 2026 15:53 #349931 by djdelorie
chattr +i foo.hal
That prevents linux itself from modifying the file (even as root) until you -i it.
But as Rod said, once you start manually editing it, you can't use the wizards any more.
