Mill Counter Bore Subroutine
- BigJohnT
- Thank you received: 994
05 Jun 2012 12:50 - 05 Jun 2012 12:51 #20659
by BigJohnT
Mill Counter Bore Subroutine was created by BigJohnT
The attached subroutines are for a mill. The purpose of these subroutines is to mill a counter bore for a socket head cap screw or similar function when the center of the hole is all ready drilled out.
The subs function as follows
Rapid to center of hole to clearance height
Turn on spindle and coolant
Feed to edge of hole
Spiral down to bottom of hole
Do one circle to wipe bottom of hole
Feed to center of hole
Rapid to safe Z
The only difference between cb and cba is cb you pick the depth of each spiral and cba you pick the angle you wish to spiral down at.
Enjoy
Rapid to safe Z
Enjoy
Last edit: 05 Jun 2012 12:51 by BigJohnT.
- Rick G
- Thank you received: 114
06 Jun 2012 08:56 #20672
by Rick G
Replied by Rick G on topic Re:Mill Counter Bore Subroutine
Good one John, will have to add them to the collection!
Rick G
Rick G
Time to create page: 1.173 seconds
