Use NGCGUI with touchy interface
01 Oct 2012 15:27 #24810 by jbunch
Use NGCGUI with touchy interface was created by jbunch
Are you able to integrate the ngcgui into the touchy interface. would it require a number pad.
Jim
01 Oct 2012 16:57 #24819 by BigJohnT
Replied by BigJohnT on topic Re:Use NGCGUI with touchy interface
I don't see anything about using ngcgui with touchy in the manuals or example configs. A pure python version might play better with touchy.
05 Oct 2012 14:45 #24989 by jbunch
Replied by jbunch on topic Re:Use NGCGUI with touchy interface
It looks like they added dynamic tabs to touchy in 2.5.0 for adding other applications and virtual control panels. Thought this might include ngcgui.
Jim
05 Oct 2012 15:39 #24991 by BigJohnT
You can add a GladeVCP panel so I'd try ngcgui and see what you get. Dunno how you might input the numbers though...
05 Oct 2012 17:39 #24993 by cmorley
Replied by cmorley on topic Re:Use NGCGUI with touchy interface
For ncgui to be reparented, it requires a small amount of code.
I looked at the code once and it seemed that the reparenting code was removed.
I asked on the mail list about it and never got an answer...
05 Oct 2012 19:52 #25011 by BigJohnT
Code missing from Touchy?
06 Oct 2012 04:58 #25053 by jbunch
As far as entering numbers etc i was thinking of a number pad.
Jim
06 Oct 2012 10:44 #25057 by BigJohnT
Like the number part of a keyboard? I could see how that can work.
06 Oct 2012 19:03 #25073 by cmorley
code missing from ngcgui
06 Oct 2012 20:19 #25079 by BigJohnT
I just emailed Dewey to see if it can be done.
Time to create page: 0.926 seconds
