OK, I found an M110 command in the code repository:
#!/bin/sh
# Clear axis info notifications
# use in gcode subroutines and/or connect to pushbutton
# M1nn files must exist _before_ starting emc
# in the [DISPLAY]PROGRAM_PREFIX
# or in a dir specified by [RS274NGC]USER_M_PATH
# the pin for axisui.notifications-clear-info is in emc-2.4pre
# using an earlier version will print error to stdout
halcmd setp axisui.notifications-clear-info 1
sleep .100 ;# requires a sleep that does <1
halcmd setp axisui.notifications-clear-info 0
# if a M1nn command fails and its script exits with nonzero status,
# the gcode program exits. So always exit 0, and make sure
# the M1nn command prints a message in order to keep on going.
exit 0
So then I created an M110 file in linuxcnc/nc_files/examples/, then set it have executable privs for all users. I thought, OK, I've got this fixed now, but NOOOO. Still have the same error when executing rectangle_probe, "unknown m code used: M110" .
What am I missing now??
