- Thank you received: 394
a very dirty fix would be to add a test to /linuxcnc/lib/gladevcp/hal_sourceview.py at line 81
orangecat wrote: Yes. It appears as if the program is stuck in the g-code subroutine handling M6, but i do not believe this problem occurs after the last M6 in a g-code file. So for g-code files with one M6 command it works as it should.
This isn't the behaviour I am seeing in the VM where I am testing a remapped T-word
orangecat wrote: I think there's additional problems caused when the M6 subroutine calls M6 (special code prevents recursion by ignoring the mapping when M6 is called inside the M6-mapped subroutine.) .
