Gcode preview and remap
21 Sep 2023 12:42 #281302 by zz912
Replied by zz912 on topic Gcode preview and remap
gcode is run in a separate interpreter for the preview and for this the parameter #<_task> is = 0.
If the code is executed 'on the hardware' (by clicking on the 'Run' button) then the parameter #<_task> = 1.
How many interpreter LCNC has?
The ATC path has disappeared in the preview. But I don't know if there have been moves in the real world.
I will try it in the real world and give feedback.
21 Sep 2023 14:59 #281319 by rmu
Replied by rmu on topic Gcode preview and remap
It no longer gives the error message, but it didn't solve the problem. Still showing path of ATC. Still, thanks for the help.
It did solve the most immediate problem, didn't it. the thing with <#_task> was explained elsewhere, if done correctly it should hide the tool change paths from the preview. You will see those moves in the "history" backplot on the real machine though.
04 Feb 2024 19:44 #292432 by TMLKyza
Replied by TMLKyza on topic Gcode preview and remap
I have qtDragon and a similar behaviour occurs, whenever I load a program that requires a tool change with the M6-remap (versa probe) the preview remains blank, and nothing gets drawn. I can see the lines of the history and such but no program-related moves.
Time to create page: 0.114 seconds
