- Thank you received: 11
BigJohnT wrote: Hardware step generation should be able to keep up fine. Are you using a 7i76 with the 6i25?
And the most important question I forgot is what version of LinuxCNC are you using?
JT
we are in the process of fixing that problem. A sample of gcode that shows the problem would help.
rob has a branch that takes care of the issue - but causes a few violations he hopes to look at this week.
skunkworks wrote: Could you give us a short gcode example that shows the discrim error? (and your ini file)
If you are energetic - you could try this branch and let us know if it fixes your issue. (it is not perfect yet)
github.com/robEllenberg/linuxcnc-mirror/...gent-improvement-2.7
sam
skunkworks wrote: What is the acceleration of you spindle? I am trying to get this to trip in sim and am not having any luck so far
