NGCGUI install HOW-TO?
  • Transistor
  • Transistor's Avatar Topic Author
  • Junior Member
  • Junior Member
01 Aug 2015 15:58 #61092 by Transistor
NGCGUI install HOW-TO? was created by Transistor
I've been using LinuxCNC occasionally for several years and stumbled across a Youtube video showing features of NGCGUI - How to make a motor mount . It looks great.
I've upgraded to 2.6 but it isn't included. I've read on this forum www.linuxcnc.org/index.php/english/forum...ay-to-install-ngcgui but it doesn't give specific instructions.
Anyone got a HOW-TO?
Thanks.
01 Aug 2015 17:26 - 01 Aug 2015 17:27 #61095 by Rick G
Last edit: 01 Aug 2015 17:27 by Rick G.
01 Aug 2015 23:25 #61105 by BigJohnT
Replied by BigJohnT on topic NGCGUI install HOW-TO?
The manual is always the best place to start. Ngcgui is part of 2.6 and only needs some additional lines in your ini file to turn it on.
linuxcnc.org/docs/html/gui/ngcgui.html
JT
  • Transistor
  • Junior Member
  • Junior Member
02 Aug 2015 19:20 #61121 by Transistor
Replied by Transistor on topic NGCGUI install HOW-TO?
Thanks, guys. It crashes out on start with an error (see below) when I use all four of the [Display] ini settings below. If I comment out the TTT configurations Axis will start but no sign of NGCGUI.
TKPKG = Ngcgui 1.0
TKPKG = Ngcguittt 1.0
#TTT = truetype-tracer
#TTT_PREAMBLE = in_std.ngc
Any ideas?
ini file contents
[DISPLAY]
DISPLAY = axis
EDITOR = gedit
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 4
INTRO_TIME = 5
PROGRAM_PREFIX = /home/cnc1/linuxcnc/nc_files
INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
# NCGGUI added by transistor
#- the NGCGUI package
TKPKG = Ngcgui 1.0
#- the True Type Tracer package for generating text for engraving (optional, must follow TKPKG = Ngcgui).
# - name of the truetype tracer program (it must be in user PATH)
# - Optional, specifies filename for preamble used for ttt created subfiles. (alternate: mm_std.ngc)
LinuxCNC errors
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.6.8
Machine configuration directory is '/home/cnc1/linuxcnc/configs/ia-mill-linuxcnc'
Machine configuration file is 'ia-mill-linuxcnc.ini'
INIFILE=/home/cnc1/linuxcnc/configs/ia-mill-linuxcnc/ia-mill-linuxcnc.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=
DISPLAY=axis
Starting LinuxCNC...
INFO CLASSICLADDER-   No ladder GUI requested-Realtime runs till HAL closes.
Starting DISPLAY program: axis
Killing task linuxcncsvr, PID=3066
Killing task milltask, PID=3116
Debug file information:
  File "/usr/bin/axis", line 3323, in <module>
    root_window.tk.call("package","require",*pkg)
_tkinter.TclError: can't read "::ngc(any,color,prompt)": no such element in array
3066
  PID TTY      STAT   TIME COMMAND
3116
Stopping realtime threads
Unloading hal components
Kernel message information:
[10672.361125] I-pipe: Domain RTAI registered.
[10672.361138] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[10672.361142] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[10672.361151] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[10672.361154] PIPELINE layers:
[10672.361159] f0c9ae20 9ac15d93 RTAI 200
[10672.361162] c085cb20 0 Linux 100
[10672.397230] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[10672.397473] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[10672.397482] RTAI[sched]: hard timer type/freq = APIC/8305580(Hz); default timing: periodic; linear timed lists.
[10672.397487] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2392151000 hz.
[10672.397490] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[10672.397699] RTAI[usi]: enabled.
[10672.539980] RTAI[math]: loaded.
[10672.654018] config string '0x378 out  '
[10672.668751] creating ladder-state
[10678.107539] RTAI[math]: unloaded.
[10678.212764] SCHED releases registered named ALIEN RTGLBH
[10678.229702] RTAI[malloc]: unloaded.
[10678.328021] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[10678.334120] I-pipe: Domain RTAI unregistered.
[10678.334136] RTAI[hal]: unmounted.
02 Aug 2015 19:36 #61122 by BigJohnT
I don't see a subroutine file in your ini. I doubt that ngcgui will show up without at least one subroutine defined. Read the manual again about TTT = truetype-tracer - name of the truetype tracer program (it must be in user PATH) .
JT
  • Transistor
  • Junior Member
  • Junior Member
03 Aug 2015 06:14 #61132 by Transistor
Thanks, JT. I'm starting to make some progress. Now to understand it!
I'll try to create a summary HOW-TO here when I'm finished.
03 Aug 2015 06:27 #61133 by BigJohnT
Great!
If you have some suggestions or clarification for the Manual I'm your guy to get that added/changed.
JT
14 Apr 2016 16:46 - 14 Apr 2016 16:46 #73316 by cncnoob1979
Replied by cncnoob1979 on topic NGCGUI install HOW-TO?
Transistor,
The video you are referring to shows "Linuxcnc-Features" forum.linuxcnc.org/forum/40-subroutines-...res-a-kind-of-ngcgui
It is stand alone from NGCGUI. Completely a separate program and installation.
It is located in this forum linked above. FernV is maintaing it.
Last edit: 14 Apr 2016 16:46 by cncnoob1979.
15 Apr 2016 10:30 #73340 by andypugh
Replied by andypugh on topic NGCGUI install HOW-TO?
It is now included in an experimental branch of LinuxCNC, though I am not sure how to get it.
We probably need to decide on where to merge it to.
github.com/LinuxCNC/linuxcnc/tree/featur...m/axis/features_demo
Time to create page: 0.246 seconds
