Unpredictable behavior of o-code subroutine
26 Mar 2020 14:26 #161569 by romeofox
Hello,
for my linear tool change I use as M6 remap the attached code with linuxcnc version 2.9.
The exciting thing is that the line G53 G1 Y100 F#29 is stopped in the middle of the movement as soon as I remove the debug output (DEBUG, MSG3) in the next line. What is output there doesn't seem to matter. Neither does it matter that immediately after that a (redundant) G53 G0 Z0 Y100 F#29 follows, which is not executed either.
;(DEBUG, MSG1)
G53 G1 Z0 F#29
;(DEBUG, MSG2)
G53 G1 Y100 F#29									(mit WZ ausfahren)
(DEBUG, MSG3)
G53 G0 Z0 Y100 F#29									(mit WZ ausfahren)
Do you know problems with subroutines that are terminated too early?
Many greetings
Robert
26 Mar 2020 18:03 #161586 by bbsr_5a
Replied by bbsr_5a on topic Unpredictable behavior of o-code subroutine
Hi
DEBUG is a Command
and MSG is also a command
use only one command in one line
so
DEBUG,mymassage
or MSG mymasage
28 Mar 2020 12:23 #161796 by andypugh
Replied by andypugh on topic Unpredictable behavior of o-code subroutine
I am a little confused by this description.
Could you perhaps show the version that works and, separately, the version that does not work?
Time to create page: 0.095 seconds
